CRF gives birth
Home Forums Tech Help Tech Help CRF gives birth
This topic contains 21 replies, has 0 voices, and was last updated by  Adrian Snowden 12 years, 7 months ago.
  • #103150
    When you in my shed it looks like the CRF has given birth as with not being able to ride for 6 months I figured I need a project in the form of a xr100 aimed at letting a couple of my daughters get into trail riding. So as this was one of those spur of the moment decisions, I’m looking for advice on any particular problems these bikes may have had that I need to check while I’m stripping it down.
    It’s a 2000 model with bugger all use and starts first kick and runs well considering it had been down the back of a farm shed untouched for ten years. I can’t see any obvious issues apart from some external cracking in the fuel tank that I assume is from being stored in a hot old shed. All help appreciated. Snowy
    #248253
    Burn it and buy a kato
    #248254
    Fresh oil, check bearings for grease as it may have dried out i.e. head stock, wheel and swing arm, have a look at the brakes as they are rather important, and lube the clutch and brake cables.
    There’s not a lot left but I’m sure others will think of something. The bikes are bullet proof but everything lasts longer with some TLC.
    I hope they get into it. It was a good day for me today riding with my son and some Old Bulls then sharing the after ride adventure over a couple of beers :)
    #248255
    XR’S are good bikes
    If its their first one it will be good
    Adam pretty much nailed also check tyres as they may be a little perished if its been sitting on the ground all that time
    #248256
    Richard W
    The first thing I would check is the top of the motor, if no oil up there for 10 years it could be a little rusty inside.
    #248266
    So I take it that’s pull the top off and have a look around?
    Can external cracks in the fuel tank be repaired or do I just find a new one and replace it?
    #248267
    Ron Birrell
    Don’t worry about Boony Snow, he’s jealous you’ve found a bike that has more get up and go than his Kato :whistle: :silly:
    On a more serious note they are pretty much bullet proof. If my bother’s kids can’t destroy them I don’t think anyone can.
    Buzz
    #248257
    Aaron Wilde
    Like the others said. Usual stuff. Look up you tube and learn how to ajust the valves. They are piss easy and chances are its never been done. Xr100’s all over Australia have been used and neglected and still front up for work again and again. Great idea snowy. Sounds like family fun coming up. B)
    #248270
    Any pictures of the new addition?
    #248274
    #248288
    Shit, going by the look of it, I’d change the oil and let them loose on it. Looks like it has done bugger all work to me.
    It is an XR mate, not much can and will go wrong with it!
    #248258
    Just one question
    How did you get it to stick to the ceiling
    #248301
    Ron Birrell
    ——h—— wrote:
    Just one question
    Superglue :P
    Buzz
    #248303
    Congrats Snowy great bike, we had them out at Orange they were ridden daily and thrashed(even fat drunk idiots racing them around can’t kill them) The one thing that does kill them is the air fitter? Air filter you say, yup because they are so reliable and never miss a beat you never clean it and over years, yes read years it falls apart!
    See the trouble was we were always working in the orange shit boxes the reliable XRs got NO love :blush:
    A little bit of work now will prevent ant dramas in the future, clean the fitter, gease it up like Adam suggested ( a great tip for years of trouble free riding that and a great boding exercise for you and the kids ) check the valve clearances like Aaron said its easy and change the oil once a year it will out last us all
    Congrats again
    http://youtu.be/V0KR2cPa8tI
    Started to strip the little bike down and Im definatley going to have to replace the fuel tank or repair the cracks in it somehow. They dont appear to go all the way through and are all located in the front / upper part of the tank.
    So
    1] Can cracks in plastic tanks be repaired?
    2] If so how
    3] If not any one got atank they want to flog?
    Cheers snowy
