CRF Valve issue
Home Forums Tech Help Tech Help CRF Valve issue
This topic contains 7 replies, has 0 voices, and was last updated by  Paul 16 years, 6 months ago.
  • #97190
    Matt Bissell
    Wondering if anyone has been been having similar problems with CRF450X inlet valve wear.
    Had heard this was a problem but having to re-shim the clearances within approx. 1000-1500kms seems a bit excessive.
    Don’t ride the girl that hard ( grade 3 trying to get fitter for grade 4 status ) and spoil her with heaps of services and love.( Maybe that’s the problem).
    Can anyone recommend suitable upgrades ?
    Am worried if I just keep re-shimming the valves will let go and with it my yearly ride budget !!
    :dry: Please help !!!
    Cheers ………Matt05
    #153203
    How many times has it been re shimmed Matt, where do you live and how do you do your air filters first please mate?
    Trent
    What year model too mate. My mates 07 has had similar issues I think.
    #153205
    Matt Bissell
    2005 Model
    I bought with 1300k’s on and think those would of been original shims.
    Replaced shims @ 2700k’s ( but must admit the gaps were only about 0.15 with new shims, max is 0.19 ). now have approx. 4000k’s ( having speedo problems ) and the same symptoms of poor starting are showing up( definitely valves again ).
    Use a Twin Air filter and use shell spray on filter oil inside and out and regularly clean and re-oil.
    Live in Rankin Park Newcastle
    :woohoo: :silly: :side: :S
    #153357
    Austblue, I think all of them have the same problems with valve recession, some people manage to catch all the fine grit in a really heavily oiled filter, but if you oil the filter like I do mine your valves will be dusted in a few rides. A set of stainless valves are reasonably priced, may rob you of a little power (sweet FA) but will last for yonks. Some people people are even buying them new and getting the dealers to insert SS valves before they pick them up.
    I believe it is the only real issdue with these bikes, they are a nice neutral handler with good oomph, a few hundred on SS valves and you’re set for life.
    #153365
    Matt the steel valves from the TRX450 quad are a good fix, I am not a fan of spray type air filter oil, I would rather work it through the filter by hand I think its far better and use a filter skin helps also IMO
    Greg Ball Engineering
    Have yarn with Greg Ball he is very cheap and does very very good work, I have used him and recommended him to Austblue and LC4 here and they have both had work done by him and are happy I believe
    Paul
    I have read many times of people using stainless steel valves to resolve the issue.
    Not sure if there is a stand out good brand for them or not.
    #153206
    Glenn
    The Stainless Steel valves offer increased durability, but due to the extra weight of the steel a heavier valve spring is recommended. The harder SS valve will last longer but the SS valve is heavy the best cure is to use a better spring package with SS valves.
    Glenn
