CRF450X bottom end failure
Home Forums Rocks Motorcycles Honda Forum Rocks Motorcycles Honda Forum CRF450X bottom end failure
This topic contains 39 replies, has 0 voices, and was last updated by  James Rookyard 14 years, 6 months ago.
Viewing 15 posts - 1 through 15 (of 40 total)
  • #100304
    Just had my bike blow up at the Yellow Mountain race. Its an 08 model I bought new. Regular oil changes but has done a fair amount of racing pony expresses and 3 Yellow mountain races and 1 Condo 750, so some high speed stuff.
    It started missing, I pulled up, it was rattling and then it seized. I just pulled the top end down and there were no dramas, but the big end bearing is seized and the oil was full of brass coloured metal shavings. I will have to split it to see what else is stuffed.
    Is this common in these 450’s? Is it worth fixing or what are the chances of finding a complete second hand motor to put in it?
    #206537
    Sounds like a candidate for a CR500 engine conversion.
    Sorry I no nothing else about CRF450’s.
    #206543
    Thats a thought.
    #206544
    The only info I could find on the site regarding a CRF450 crank is this gem. Dunno if it will help or not, it will let you know what you are up against.
    It appears that they aren’t that big of a drama to rebuild.
    CLICK HERE
    #206546
    just get it fixed and go again cranks are not that dear but labour to fit them is
    #206547
    CRF’s only have std crank $281.15 and stroker crank $376.15 . dunno on post though.
    http://www.crfsonly.com/catalog/advanced_search_result.php?keywords=450x+crank&osCsid=7e1de71a5ee26c9289f90936fb8a9f45&x=0&y=0
    if the crank it’s self is good. a rod and bearing kits aren’t over the top either. as rocket said coin for spanner time is the biggest cost factor.
    #206538
    Bob Dowsett
    Just bury it :pinch: :whistle:
    #206548
    Not to worried about pulling it down and putting it back together. New crank may be the go. Where has all the brass coloured metal come from?
    #206551
    Bob Dowsett
    Sorry that was a bit harsh
    your probably in a world of emotional pain hope it all works out
    #206553
    Bob Dowsett
    stab in the dark ………….Clutch area ???
    #206555
    Gearbox and engine oil ar seperate so cant be clutch can it?
    #206554
    thats from the crank mate B)
    #206556
    Not too familiar with them but most rods have brass little ends(piston pin bearing).
    Good luck with it. ;)
    #206552
    :laugh: Could have buried it on Sunday when it went bang! I was heading for a top 30 finnish:angry:
    #206557
    Thanks for all the quick replies! Helped me heaps already. Now who wants to buy a one lady owner crf45ox, never been raced?
