Cush drive rubbers Tenere
Home Forums Yamaha Bikes Yamaha Bikes Cush drive rubbers Tenere
This topic contains 10 replies, has 0 voices, and was last updated by  Sean Ramsay 10 years, 7 months ago.
  • #103919
    This question is probably aimed at TB.
    Is there anyone in Australia manufacturing polyurethane cush drives for the Tenere?
    I have only done 1800klms on mine and there are already signs of wear….rubber flaked off and disintegration.
    I’m sending my suspension to Teknicks for them to work their magic and have also included the cush drive to have the larger bearing fitted and want to fit polyurethane cush while it’s all apart.
    Rubber cush drives don’t make sense since rubber reacts with oils and grease which no doubt makes its way into the drive from the chain.
    #256759
    Is there anyone in Australia manufacturing polyurethane cush drives for the Tenere? No the guy is South African contact details for the polyurethane rubbers are $95 dollars a set incl. postage
    you can pay through paypal. email accentgt8@gmailcom
    I have only done 1800klms on mine and there are already signs of wear….rubber flaked off and disintegration. Yeah thats normal, with the twin bearing mod I am getting 10,000 plus now out of mine. The flaking is like a tyre wearing, I worry that the polyurethane ones may wear the hub rather than the rubber :huh: Rubber is cheaper than a hub and I havent seen anyone do any decent miles yet with the polyurethane ones
    I’m sending my suspension to Teknicks for them to work their magic and have also included the cush drive to have the larger bearing fitted and want to fit polyurethane cush while it’s all apart. You wont understand how you rode it with the standard suspension
    Rubber cush drives don’t make sense since rubber reacts with oils and grease which no doubt makes its way into the drive from the chain. I dont oil / lube or grease my chain because it is lubed inside the rollers and lubing the outside only gives the sand something to stick and make a very abrasive paste thus wearing your sprockets. There should be no where else oil and grease should come from is there? Every brand uses rubber bushes that I have ever seen
    Hope that helps
    Dave Wiggin
    Where do you get the genuine Yamaha rubber ones from?
    Wigster
    #256761
    Thanks TB, I think I’ll give these polyurethane cush drives a go. Just don’t want to have an issue in the Gibson when doing the east to west.
    Wigster, call your nearest Yamaha dealer, I recon they would be on the shelf considering the rate they destroy themselves.
    #256762
    Get the rubbers from the Germans (off the road). They are heaps cheaper than your local yammy dealer.
    #256763
    Alex Rogers
    Some guys on xt660 have come up with what looks like a very cheap and simple preventative measure. http://www.xt660.com/showthread.php?p=113529 for a decent pictorial. Can’t vouch for it, but looked handy.
    #257827
    Wayne Drew
    Hi guys
    I cut the rubber bridging off mine making each rubber block seperate and then found an old push bike tube
    which I streched over the rubber blocks , cut them off to length and never had an issue since.
    cheers
    Drewy
    #256764
    I fitted the polyeurethane ones from South Africa. They are a nice tight fit, but had a bit of stuffing around to get the wheel assembly to fit into the swing arm. Had to grind a bit off the depth of the “cush rubbers” to make them fit.
    They are definitely a harder compound, probably don’t offer as much cushioning but reports are they will last at least 50k.
    Someone should should start moulding them in Australia.
    #256765
    Was thinking of doing the bearing upgrade and the polyeurathane rubbers, would like some idea of what lifetime I will get outta them though!!
    #259101
    Off The Road in Germany has Tenere Cush Drive rubbers at a very reasonable rate.
    They appear to be made of better, more durable rubber than the OEM ones.
    They certainly last longer than the OEM product, I am doing some hard riding and getting easy 7,000 k’s from them.
    If you get a few sets, and some for your mates, it makes the postage and price well worthwhile.
    Check out their site, everything for Tenere’s.
    I don’t mind having to change them regularly, it gives you the chance to have a good inspection of the hub, I check mine every tyre change regardless of k’s .
    regards,
    Shane 660
    #261448
    Sean Ramsay
    seems there are a few tenere owners here, can we do a obt order?
