DR400 Cylinder head removal, a D.I.Y for everyone
This topic contains 19 replies, has 0 voices, and was last updated by  Greg 14 years, 9 months ago.
  • #200349
    John
    Bloody good stuff. ;)
    Only problem is i have around 10,000 k’s to go before i have to do it. 😆
    Thanks for taking the time to do these DIY pieces.
    #200350
    Krusty wrote:
    snowy09 wrote:
    Ok TB my stupid question for the day. Apart from the bike not wanting to start cold, is there anything else that would cause me to have to go through all this to check the clearances. Or put another way, if I have no problems starting I take it I should just leave the clearances alone and not worry?
    Look here Snowy… http://www.obtrailriders.com/index.php?option=com_kunena&func=view&catid=72&id=92957&Itemid=75
    Jsut ignore my ugly mug :laugh: :laugh:
    Damn I forgot I even made that video :blink:
    There you go Snow ;)
    Cont.
    I whipped the head down to Teknik’s has they do cylinder heads as well unknown to most. Nick stripped the head straight away and put the head in the hot wash while he bead blasted the valves so we could inspect them.
    Removing the valves
    Cam, buckets and collets
    Nick bead blasting the valves for inspection
    It’s very hard to show the valves and the wear with a little camera
    The sealing face should be flat, as you can see it had beaded and is dished
    The valves seats below should be flat like the valve face should but isn’t, naturally if the valve face is dished the seat it’s wearing partner will be the same. The camera doesn’t show it but the seats are rounded.
    The other component of interest is the automatic decompression setup on the exhaust cam and how it works seen here on the exhaust cam
    A video on how it actually works, the speed it throws the weight out and stops opening the exhaust valve is about 700rpm
    http://www.youtube.com/watch?v=bp5hCMnMTtg&feature=youtube_gdata_player
    Sorry for the delay as I took the head down there the day i took the head off but have been flat out and hadn’t loaded the video etc
    More when I get the head back and put it back together
    Clive Carre
    Mate
    I’m just blown away by all this, I joined old bulls to ride with blokes who share my passion but now know how to strip my DRZ 400 head down, drink Bundy and bullshit around camp fires:ohmy: TB thanks once again mate, not only for doing the job for me but also taking time out to show everyone else how it’s done.I’ll buy you some bundys on our next trip and promise not to drop your pants in front of folk singers ever again:woohoo: Well only for the next trip anyway !!:evil:
    Cheers Mate Fish
    #200316
    Well the DR has been put back together and is running like a dream. If wants to under take the same job I am more than happy to assist with instructions, tensions or whatever is needed.
    Tekink’s did the cylinder head work, it included new valves (Kibbell valves better than standard) seats and all required machining work. They shimed the buckets and set all the clearances so the head was ready to fit. They also supplied the top end gasket kit for just over 400 bucks all up ;)
