DRZ Oil Pump Gear failure
Home Forums Mud n Tar Suzuki Bikes Forum Mud n Tar Suzuki Bikes Forum DRZ Oil Pump Gear failure
This topic contains 3 replies, has 0 voices, and was last updated by  corey heather 14 years, 2 months ago.
  • #100908
    While at a local bike shop recently watching Boony sell his sole (didnt get much for it as it was pretty well flogged) the shop owner was dealing with a bloke who had stuffed his 2000 model drz after the oil pump gear had failed and the motor had seized as a result. The shop owner/ mechanic mentioned he had seen a few such cases recently and the cause was the oil pump gear which is the only gear apart from the water pump that is plastic. The plastic gear cooks in the oil over time and deteriates becoming brittle and then it fails.
    As I had my bike pulled down for a full service I figured Id check as while my bikes an 09 model it has been getting plenty of use. Sure enough the old oil pump drive gear was a similar hue to a burnt chip and looked as old as me mum. Bought a new one for $20 and its bright white and shiny in appearance.
    I’m no mechanic but for the time to pull the case off and fit a new cheap part I reckon its safer than risking a fialure that could cost big bucks.
    #214258
    For a good piece of mind you can also replace the dr with a 250 they are the taste of 2012 by the looks of things!! Might take the 300 cylinder off and drop the 250 on the gasser or i might not be able to go on future rides haha!!
    #214259
    Well done Snowy as mine is a 2000 and is currently stripped down i will be checking this for sure mate. Thanks fello cool DRZ rider. B)
    #214266
    Thinking of getting a sticker made up saying 250cc + 150% man
