drz rotor thickness
This topic contains 4 replies, has 0 voices, and was last updated by  Greg 16 years, 5 months ago.
  • #97245
    Mark Murphy
    I’m doing the rear brakes on the Drz and not sure of the thickness of the brake rotar. If anyone can help out it would be appreciated. One shop I asked said 3mm another said 2.5mm
    #154475
    2.5mm is the minimum spec mate, but just bang some pads in it it will be OK mate
    Thanks to my mate Boulder, I have the service manual for the 2000 to 2007 DRZ400 and it states that the disc’s should be minimum 2.5mm. It also states and I don’t know what this means is that the brake disc runout limit is .3mm. TB will be able to confirm this but I am thinking that this is the variation in thickness around the disc (?)
    Thanks Boulder!
    #154488
    Yes Kylie that’s exactly correct
    yep min thickness is 2.5mm
    Kylie run out is the distance that a disk runs out of true,in this case max 0.3mm
