drz setup- getting started
Home Forums Mud n Tar Suzuki Bikes Forum Mud n Tar Suzuki Bikes Forum drz setup- getting started
This topic contains 46 replies, has 0 voices, and was last updated by  Mick D 16 years, 9 months ago.
Viewing 15 posts - 1 through 15 (of 47 total)
  • #96437
    john morgan
    putting out a few thoughts on where the new DRZ`er should spend their hard-earned and get bang for buck.
    following asumes bike is standard when picked up.
    . remove restrictors – nil cost
    . remove excess plastic and place in a box to forget about, include the rear taillight assembly
    . buy a smaller profile taillight/plate holder- some options here , price depends on material used,plastic or aluminium or even stainless.
    . buy some smaller blinkers-again range of options here but buy for front and rear – I recommend cheap ones as they get broken often
    . buy hand guards,with aluminium re-enforcement.”barkbusters”
    . buy new hand grips- stock ones are crap.
    . buy a set of bars- plenty of options here , but any thing better than stock steel ones.
    . if you tall, buy a set of bar risers- money well spent.
    I would recommend buying bars,risers,grips and barkbusters at same time as bike shop should sell gear that will mate up first time and THis is probably most noticable improvement to the bike`s feel in the initial stages.
    . more money- more improvements…
    . look at bike gearing- dropping down one tooth on front cog gives good results in bush riding for little outlay- $20-25 .
    . bash plate- good insurance
    . tyres to suit your riding area + heavy duty tubes!
    still got money in wallet…
    . polisport or similar headlight- replace the heavy stock item
    . aftermarket exhaust- save weight,slight power gain
    After this suspension would be next area to look at.
    These are just my personal thoughts, any other ideas welcome as I`m always looking to get a little more out the bike for not much coin.
    DRZ – they just keep goin
    Morgo
    #135638
    I would strongly recommend rad gaurds,case savers and a manual cam chain tensioner.
    good insurance for the buck.
    #135652
    I still say that the best set up for a DRZ owner is to trade it on a KTM:laugh: :laugh: :laugh: :laugh:
    #135656
    Fez
    Now that is harsh RAT. I was going to say the same thing about going BLUE but I thought it more appropriate to leave this educational thread alone. FEZ.
    #135639
    If you have the funds you could do this.
    #135659
    But I was being educational:laugh: :laugh:
    DRZ are real good bikes for most normal people….I am not normal:laugh: :laugh:
    #135657
    Hey rat ( blowing raseberry) bite me
    all mod explained have been done to the boon mobile (except new bars) but there now needed
    The darn thing is still way to top heavy but as stated the thing just keeps going. we DRZ riders have to appreciate that they are not like them there high reving 4 strokes on the market at the moment (there better)
    honestly all mentioned mods have helped but you can add #26 fork springs, replace rear spring, all up decent mods that I have seen on DRZ suspension costs about $900.00.
    the best mods are what was first mentioned and get decent rubber and ride the thing within its limits.
    #135653
    I agree 100% with what Boulder has said.I probably would also consider changing the speedo assembly for something a little less pricier to replace and the front suspension needs to be stiffened up.Also a JD jet kit makes a difference IMHO
    #135660
    mentioned the fork springs but how much more performance and in what range does the jetting and exhaust modifications give the mightyDRZ
    menace is obviously not allowed to play or he would be all over this one
    #135658
    Puddles
    i don’t think there is much differance between yellow & orange. the best thing you all could do is go [color=]blue [/color]:laugh: :laugh:
    #135664
    why would I want to by a husky or one of them there TMs huh thats just silly poodles:woohoo:
    #135662
    yeh mate you posted as I was writing:laugh: The jetting kit probably doesnt give it more power,it just makes it easier to start and the power is a lot more responsive. Also improves fuel consumption. During winter the engines of your bike will run leaner due to more air being available. so you use the blue tipped JD needle,In summer or on very high altitude there is less air available and the bike will run rich,you then use the alternate red tipped needle. Well worth the Coin,also a exteranal fuel mixture screw makes it easier to set it up just NOICE;)
    Yes Only a blue owner would say there is no difference between yellow and orange
    ……do I have to show you everything
    ….their spelling is different:laugh: :laugh: :laugh:
    #135667
    Poodle….Ha Ha Ha Ha Ha…Karma for that one my man:laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
    #135669
    Puddles
    Time for you to go night night rat
