DRZ400E Top End
This topic contains 5 replies, has 0 voices, and was last updated by  Greg 15 years, 2 months ago.
  • #99483
    Ok.. I need to have my valve seats done and new valves to get past the need to shim every 2500k :ohmy: :angry:
    I plan on getting this done shortly after the Nabiac ride..
    While I have it torn down I was wondering what everyone might think about having her honed and re-ringed? I know that it will be easier to tell once she is broken down however I was just wondering if anyone thinks, I mine as well go the one step further?
    Cheers…
    #195366
    It’s a question that can’t be answered because the are so many things you don’t know, I should have explained when I said before won’t know till it’s apart
    What affects whats found when the head is removed
    Previous owners maintenance practices (tipping they weren’t good cause the top ends worn out)
    How long was it ridden dusted, maybe that’s why he sold it? It’s worn the face of the valves so again I am tipping it won’t have done the chrome face of the rings or cross hatch any favors. That said I have seen people get away with it a few times could when pulled down it’s fine. (chops didn’t really need it at 6000km but we did it because it was apart and seemed silly not to. It could have happily run it but didnt)
    You don’t know how many klms or hrs its done (can you believe the guy or previous owners?)
    Then I could find that it has a lip in the bore and honing will give it to large a ring cap when standard rings are used and needs boring. Oversize piston and rings required then. Bestvwait till it’s apart I think
    Chops was dusted and was bored and next size piston installed ;) I just checked
    I hope all that helps
    Cheers for that TB..
    #195369
    How many K’s are on it Krusty? Mine is up to 13000 with no problems at all, I had the valves checked just after it hit 10,000 and they were still spot on.
    #195398
    Difference is Jeffro he bought it 2nd hand and it has closed valves when he bought it (it was hard to start cause it had been dusted) no history or really know how many klms :(
