EBC brake pads
Home Forums Tech Help Tech Help EBC brake pads
This topic contains 3 replies, has 0 voices, and was last updated by  Greg 13 years, 11 months ago.
  • #101231
    Just got some EBC brake pads for my 2010 Berg, the packet for the rear pads says don’t use original backing plate and insulation.
    I assume this is because the pads are thicker than standard, the last set I put in were EBC and this warning wasn’t on the pack.
    Anyone got any ideas?
    #219231
    LC,
    Will the plate and insulator fit in with the wider pads?
    And do you use your rear brakes alot and overheat them?
    The answer to these may answer your questions :P
    #219232
    adam wrote:
    LC,
    Will the plate and insulator fit in with the wider pads? Don’t know yet, haven’t tried them just being a slack arse and trying to get anyone elses opinion
    And do you use your rear brakes alot and overheat them? Yes I use them a lot, don’t know about them overheating
    #219234
    I removed them when I fitted mine as it says and suffered brake fade on the next ride as Crash will tell you as I whinged to him on the blue tooth :laugh: . Fit them if you can LC
