Electrical Problems
Home Forums Tech Help Tech Help Electrical Problems
This topic contains 34 replies, has 0 voices, and was last updated by  Anonymous 16 years, 9 months ago.
Viewing 15 posts - 16 through 30 (of 35 total)
  • #136556
    Pm sending now Al
    #136561
    shane
    In ‘e noice?
    Fairdinkum TB I reckon I can see your halo shine from way up here!:laugh:
    #136557
    old al wrote:
    Thanks TB. Let me know where to send it and I will get it away straight away.
    old al
    Done all good Al, will have a play on Thursday or Friday depending on how quick it fronts shouldn’t be an issue from experience
    I will enjoy the tinker :)
    Post or courier Al?
    #136591
    Post or courier Al?
    I will stick it in the post TB. No great rush to get it back. I will do the valves while I have plenty of room on top of the engine.
    old al
    #136596
    shane
    Any chance of doing it on the weekend and teaching an old bloke some stuff?
    #136802
    Sorry Shane its done :(
    #137165
    Al,
    I rewired your harness today, what a mess :ohmy: Problem was a headlight power rubbed through to an earth thus creating a direct short, this heated the wires for the charging circuit and melted them together causing all sorts of dramas, but didn’t take out the two glass fuses that are in parallel as well as the spade fuse you spoke about in the first post :huh: :huh: :blink: ???
    I will PM you my number pls give me a ring tomorrow (am going to crusty demons tonight)
    I have sent it back TNT freight you should have it Monday mate ;)
    Tremendous Greg. The two glass fuses were untouched and the plastic on the 20A “main” fuse was melted. I assumed the fusible link under the plastic was blown but I don’t know as I threw the thing away.
    Thanks again.
    old al
    #136328
    Nice Work there TB,
    Old Bull Spirit shining thry & thru;)
    Thats what makes this group so good,,,,,,,,,,,
    #137190
    glass fuses were in parallel???????
    thats wierd….wouldnt that mean twice the current to blow one and even then it would still flow current through the other one???
    what were the glass fuse ratings compared to the blade fuse??
    if they were all the same, that would be a problem from the start….
    were the blade fuse terminals dirty TB? bad connections mean resistance and resistance means heat especially with a high current dead short!!:blink:
    i love magic smoke to me it smells like money……
    being a sparky and all:laugh: :laugh:
    #136329
    MENACE “i love magic smoke to me it smells like money……
    being a sparky and all”
    I thought you were a SUPERHERO buddy:P
    #137196
    only part time my good man;) :laugh: :laugh:
    #137194
    The fuses of the KLX250 as described by the Cyclepedia workshop manual.
    “The electric start KLX250s have a main fuse (check this if none of the electrical systems work) and two sub-fuses, one for the lighting system and one for the cooling fan system. Fuses are designed to protect the wiring harness and other electrical components from damage. If any electrical systems don’t work, one of the first things to check are the fuses.
    Main Fuse
    If none of the electrical systems work, check the 20 amp blade type main fuse.
    The main fuse is located on the side of the starter solenoid. Remove the main fuse and see if it is blown, replace as necessary. A blown main fuse indicates a short circuit that must be located and corrected.
    If none of the lights work, check the 10 amp 30 mm long glass type lighting fuse.
    If the cooling fan does not work, check the 10 amp 30 mm long glass type cooling fan fuse.”
    Obviously something did not work to protect my wiring. It was really fried.
    old al
    #137203
    your pretty luck it didnt burn to the ground Al….and take your house with it :(
