Electrical Question
Home Forums Tech Help Tech Help Electrical Question
This topic contains 9 replies, has 0 voices, and was last updated by  Jeffrey Smith 11 years, 4 months ago.
  • #104228
    So the aftermarket headlight cowl on the 690 was coming away due to poor mounting technique (keep it clean guys) so I pulled it off to strengthen the setup and in doing so I came across this electrical connector that has burnt out. It is for the heated grips and I assume is on the low temperature side of the switch as only the high setting was working.
    So the question is, what is it and where can I get a replacement?
    #260060
    Its a resistor, not sure if you can buy them separate. Try Scott at Sutto’s or Brad at Ballards
    And yes its needed, I will look I may have a spare kit that has been robbed
    Thanks mate. I will try Jaycar as I head back OS on Thursday morning. If they don’t have them I will try the others when I get back
    #260061
    Jeffro,
    Jaycar certainly sell them.
    You need the resistance and wattage, hopefully still visible on the old one.
    #260065
    Your right Adam, Jaycar do sell them (all sizes) but knowing what resistance and wattage is the big thing and unfortunately the markings on the old one are long gone. I will need to do some research to find out what is required including working out what brand the grip warmers are. Lucky winter is a fair way off.
    #260062
    I had the same sized resistor on the heated grips I used to run.
    I put a strip of heat shrink over the top of the resistor and it gave it some protection from doing what yours has done Jeffro. I did have one fall apart early days and sourced a new one from Jaycar.
    I may have a spare resistor here somewhere too mate, I will dig around in the cave and let you know if I find it. You can have it if it`s still there mate (next time your home for a visit) ;)
    #260066
    Thanks Eags
    #260067
    Steve
    wtf are heated grips .haven’t needed a hot water bottle (to go to bed ) for years.
    harded the bugger up.get some bark busters,will take away the wind chill of your little fingies.
    toes :)
    #260063
    Sorry mate :whistle
    I have failed to find it this evening,,, I will continue to look and if it turns up it is yours.
    I did however do some prep on the 690 for the upcoming Nav ride :)
    #260069
    toes :)
    Thanks for the tips toes, I will take them on board mate. ;)
    p.s. I didn’t fit them, they were on the bike when I bought it
