Engine Rebuild.. Where to go?
Home Forums Tech Help Tech Help Engine Rebuild.. Where to go?
This topic contains 20 replies, has 0 voices, and was last updated by  Trent 16 years ago.
  • #173500
    Austblue wrote:
    I’ve heard good things about these guys but haven’t used them myself. You might be able to get someone locally though – any suggestions guys?
    http://www.electrosil.com.au/default.htm
    Does the DT have an electroplated bore coating? I am not sure I know the old ones didnt and I dont know why they would change it really. A machine shop like repco on Manns Rd West Gosford will machine it when you give them the new piston.
    Trent
    What a team of good blokes, go ahead and do it Ontherun as Murph said you have done it almost once already. Get the piston organised, get it bored by a machine shop to suit the piston and away you go. If you get stuck post up we have rebuilt AB’s bike here god knows how many times :laugh: Murph will help you out, take some pics and tell us how it went you will be fine mate.
    Good on everyone
    My bike has never been rebuilt ;)
    My old bike on the other hand….. :D Of course if I asked the right questions the first time it would’ve only been rebuilt once and technically I suppose it was but steps 4 through to 10 were probably repeated two or three times :P
    Mind you I gave the new buyer the old piston and rings as spares as there was not a problem with it. I only rebuilt it because I wanted to eliminate that as the problem and with the head off it was suggested I may as well do it.
    #173507
    Good on everyone
    It was a great example of how tech help here worked :)
    Trent
    I’m a walking talking example of how tech help here worked and although experience helps retain the knowledge I couldn’t have experienced what I did without the guidance I had from this place. Certainly makes the donation I made before I even settled in seem insignificant when you consider the cost of trying to learn that stuff without friends that can help.
    I recall posting on another site asking how to remove my exhaust and it took about a week to get a serious response and as a result I missed the next morning’s ride where if someone had’ve given me the answer I needed it would’ve taken 5 minutes to change the exhaust instead of half a carton. Granted that may happen here if you accidentally post outside the tech help forum if you get that much right you’re almost guaranteed a running start.
    Muchos gracias a los toros viejos!
    #173512
    Paul Mewing
    Thanks heaps guys for all the quick responses and encouragment. ;)
    I will pull her apart and give it a go myself. I just have scary memories of as a young teen saving up for months to buy a piston and rings for beloved ride, installing myself thinking I did a great job only to have it seize almost straight away. I forgot about the relatively new shop at Morriset, I will see if they can look after me for some parts.
    Should give me a great sense of acheivement to get her running properly.
    Any tips on determining if the big end bearings are had it? :huh:
    #173528
    Trent
    What had you gotten wrong as a young fella?
