Exhaust Bung
Home Forums Tech Help Tech Help Exhaust Bung
This topic contains 14 replies, has 0 voices, and was last updated by  glenn 14 years, 1 month ago.
  • #101033
    Why do people have the exhaust bung in when towing their bike to and from a ride?
    Some even go to the extent of taping up the exhaust???
    I have a bung that I use when washing the bike then I take it out and start the bike to make sure any water that might have got in is blown or burned out.
    How much water from rain can get in whilst on the trailer? Not enough to worry about it I reckon….
    #216033
    I use a bung all the time because of the bloody mud wasps up here love building nests in your pipe !!
    #216036
    I have heard that leaving the bung in the pipe during storage isn’t such a good idea as it will trap any water and or condensation in the pipe. Dunno whether that is an issue or not. I dont keep them in my bikes during storage as a rule.
    #216037
    Good point, I had a generater with a wasp nest in the exhaust, took ages to figure out why it wouldn’t start.
    #216038
    Yeah Mick you should run the engine and bung the exhaust when hot. It is also to help prevent damp air / moisture in the air from entering through the exhaust valves if they are open allowing surface rust to settle on the valve seats and in the cylinder bore
    I also always make sure my engine in on TDC so all the valve are shut ;)
    I do it cause it Looks cool.. doesn’t it help keep dust out when you travelling on dirt roads?
    #216040
    As soon as you start it up any tiny amount of dust would blow straight out.
    #216041
    something to do with negative ionisation :unsure:
    I dunno, I got nuthin :laugh:
    I agree those wasps are a pain,happened on my old Husky 430 , Was running sweet as a Peach when I parked it. 3 months later wouldnt start,when it did it wouldnt rev , blamed my younger brother for muckin around with stuff he shouldnt :laugh: I was mightly embarrassed when I found out what it was :blush: , Sorry Shano B)
    Yes I would mhave to agree with TB. Although there is another good reason to run an exhaust bung, especially if you have say 3 bikes on one trailer and one is put on backwards so bars don’t clash etc. All the air, water dust etc when travelling will enter your pipe (on the one facing backwards) and if you exh valves are open this crap has the potential to enter your engine, with the possibility of causing damage. :huh: :ohmy:
    Lefty
    #216034
    Roy
    When I first got back into bikes I asked the same question and was told it was to stop dust getting in during travel. So I thought about it for a while and said “so it has to work its way up the exhaust and into the cylinder if the piston happens to be down and into the valves if they happen to be open”. I’ve never believed it could be an issue and never bought one. Maybe there is some potential if a bike is backwards on the trailer like Lefty said. I do have a bung now but it is only for washing and I take it out as soon as I’m finished (well nearly every time). I must admit though that the main reason I take it out straight away is that otherwise I will forget and it is embarressing when someone has to tell you why your bike is not starting.
    #216060
    I pack one when we do a three day ride as I find them the only effective way of shutting Boony up
    #216063
    Ha,Ha,,,
    If didnt talk to you,,you would be a very lonely man!!!! 😆
    #216044
    Lefty
    +1
    The only time the bung is out of my pipe,is when its running.
    I have nearly 15,000 DIRT ONLY KM on my bike and havnt had any dramas with the motor at all.
    …spud…
    #216045
    Bill
    Lefty
    Maybe if your inlet valves were open and the air filter out and cover off
    better off making sure the bike is in neutral on the trailer so you dont get the ring bore damage from the bike rocking on long trips
    #216035
    Bob Dowsett
    My bike got a wash at Bellingen :laugh:
    If your having valve issues buy a WR :laugh:
    Boony has got one for his Goat not his bike :ohmy:
    You would think it would be feasible to stop all of the above, dust ,water ,rain .hot air , cold air ,wasps ,mice , also would inhibit people from throwing bottletops in there as this then becomes a oh&s issue as they fire out at a rather fast pace and could hurt someone don’tbthey lc(this bit was just to keep it valid in the tech help section)
