Exhaust “spooge” on a 2T
Home Forums Tech Help Tech Help Exhaust “spooge” on a 2T
This topic contains 9 replies, has 0 voices, and was last updated by  Alex 13 years, 4 months ago.
  • #102057
    Darren
    Does black crap dribbled down the end of your pipe mean that the jetting is rich?
    Seeing as I spend most of the time in the throttle range of the needle (not initial range of Pilot Jet or last bit of Main Jet) I’m guessing I need to drop the needle one clip?? It “feels” fine (i.e. not spluttery or anything) so just concerned I’m chasing that illusive “magic setting” and could blow the bejeezus out of my engine! :S
    Should the end of the pipe basically run clean on a modern 2T?
    PS I’d post a photo but I’ve already cleaned the bike from last weekend’s ride … it’s a Virgo thing, can’t stand anything dirty! :)
    #232180
    Steve Wyeth
    Yes the pipe should run clean. Spooge can be poor oil or too much of it but is more likely jetting. You are running a fully synthetic oil right? 2% by volume or less?
    Are you running a 35 or 38PJ I can’t remember? What needle and clip too?
    You can drop a clip which might sort it but if everything else is stock and you’re running that 38PJ in these temps it will be part to blame.
    #232184
    Darren
    I’m running;
    Motorex Cross Power 2t at 40:1
    JD Kit 38PJ
    JD Kit 162MJ
    JD Kit “Red” needle clip 4
    AS 1.5 turns out
    Still waiting for the NECJ needle from the US (the joys of online shopping).
    #232185
    Id be running 50.1 mate. I do in the gasser and Its never got drips of oil only a light ring of it around the end.
    #232188
    what sort of bike is it i no my 300 runs like crap with a 38 pilet jet i just run a 35 pilet 165 main can not remember the needle i run axels jetting specs runs okay when the pipes not smashed or leeking i run 40 to 1 ratio to
    #232199
    Steve Wyeth
    38PJ is too rich, especially with a stock set up and a JD needle, slap the 35 in and run 50:1 ( your owners manual suggests 60:1) and the only spooge you’ll have will be in your pants.
    #232206
    You should easily be able to hear if your rich or lean. Too rich it will make kind of 4 stroke burbling sound and to lean it will lack torque off the bottom. You will probably also notice at the end of a single track it will take a bit of a clean out to clear the pipe. I made mine to the point it was on the edge of too lean then bumped it up a size as i found it made more torque with a touch more fuel.
    #232209
    Darren
    Suzuki RM250 “triple-taper” NECJ needle just arrived in the post :woohoo:
    So; I’m going:
    50:1
    35 PJ (stock)
    NECJ needle clip #3
    162 MJ (JD Kit)
    Fingers crossed I don’t blow the crap out of it :S … bring on the pants-spooge! :woohoo: :woohoo:
    #232212
    Steve Wyeth
    It will be sweet with that set-up mate and not even close to being lean or causing damage to your motor.
    Set the airscrew at 1.5 turns out and adjust from there. In (clockwise) is richer, out (anti-clockwise) is leaner. Adjust initially in 1/2 turn increments to see which way feels best and then tweak in 1/4 turn increments :)
    #232213
    40:1 rocket no wonder I choke riding behind you.
    50:1 & 35p here.
