Finke 2010
Home Forums General Bike Talk Finke 2010
This topic contains 86 replies, has 0 voices, and was last updated by  Mal 15 years, 8 months ago.
Viewing 15 posts - 1 through 15 (of 87 total)
  • #98145
    Stuart
    Entries have been out for a week and a half now & I’ve got my confirmation email.
    Who else from here is riding this year?
    #172609
    Scott
    Looks like just you and me at this stage!
    #530 WR450
    #172610
    Brett
    Few Lads from the Central West,I know are racing this year, don’t look like I will get out there this year, but you never know…
    MacKa….
    #172611
    I will be going this year but only as a crew member. I will race next year.
    #173291
    What a week :silly: look forward to the reports, have either of you guys done the race before?
    Scott
    Yeah I did it in 2008, I high sided it at a pretty reasonable speed, which shook me up a bit, still finished but wasn’t real happy with my effort. First time for SB_250y
    #173348
    sounds like a good ride just had a read of the web site bit like yellow mountain but more dollars and you need three pit crews
    #173365
    Stuart
    You don’t need any crew as the club are providing fuel at the fuel stops this year ($$$$)
    They will also transport some spares to Fuel stops as well as the overnight @ Finke along with your Swag ($$$$)
    They also provide meals if req if required at Finke ($$$$)
    We’ve taken the Fuel option & will have crew at Finke
    #173368
    Good luck its no walk in the park thats for sure ;)
    Stuart
    badbowie & I bought some spares for Finke last friday after some spectating at the A4DE
    Should have most of the spares we’ll need.
    Will update as the bike builds progress as we get closer to Finke
    #175718
    Good luck guys. Hope you don’t have to use any of the spares.
    Thanks for droping in while I was getting the rock star treatment at the 4 day too.
    Do you know what numbers you are in the Finke yet?
    #175864
    Scott
    Hey Mal, was good to catch up, I’m really keen to give the 4 Day a go now after having a look. Don’t think I’ll be heading to Mackay for next years though.
    My number is 530 for Finke and 430 for Hattah
    sb_250y I think is 671 for Finke and 471 for Hattah
    #175876
    Stuart
    Bike prep has started as we are approx 6 weeks away from Finke.
    Followed closely by Hattah, Then Yellow Mountain as well as a couple of Club Enduros & possibly The Holbrook 6 hour
    My 09 WR450 is just over 12 months old & approx 3500kms on it, mostly singles although it has done a couple of club enduros & Yellow Mountain & an enduro that replicated YM although only 3 hours managed 10 20km loops in this time.
    So the WR has been held wide open a fair bit.
    When it was new it had the headset bearings greased as Yamaha do a half hearted job. 12 months on the top bearing is pitted & a terrible brown colour so it’s been replaced
    Close up of Bearing
    Then onto the top end, New piston & rings
    Deglaze of the bore
    New & old
    Fitting to barrel
    Fiited to Crankcase
    Checking Valve Clearances All good haven’t moved yet (must be looking after my air filters)
    #175877
    Nice work sb. Why the piston change? Is it just to be sure or did something happen to make you want to change it.
    That bearing sure looks shagged. Lucky you found that before the Finke. :ohmy:
    Keep the updates coming mate. Is badbowie changing a piston too?
    #177008
    Stuart
    Mal no problems with pistons in WR’s. If I was only trailriding I wouldn’t contemplate changing, was after last year flogging I gave it I decided to get in ahead of this years flogging.
    There was no wear, & the bore was like new, hopefully cheap insurance.
    badbowies bike was only trailriden last year due to his big ADV ride to Finke http://www.advrider.com/forums/showthread.php?t=482329 & was out for a couple of months due to injury, so his bike has done less work than mine
    The bike went back together for a quick run then a strip down to sort the suspension, grease the swingarm & linkages & fit some TM Designworks Bling.
    Hopefully it will be back together by the end of the week, with only normal maintenance before heading off for Finke
    Will post more photos later as I’m away from home this week
