First ride with the Leatt
Home Forums Product Reviews Product Reviews First ride with the Leatt
This topic contains 0 replies, has 0 voices, and was last updated by  Chris 17 years, 4 months ago.
Viewing 1 post (of 1 total)
  • #95169
    O.K I gotta say first up that I really didn’t notice I had it on, there was a bit of talk from the boys at clarence about it and a couple of comments but nothing out of the ordinary. I guess I’m pretty lucky as it pretty much fit straight out of the box I can imagine you can spend some time setting these things up as there are so many possible adjustments. There was a bit of talk at wether the piece on the back goes under or over your armour, I had it under the armour with no real restriction of movement. Turning your head 90 degrees is a bit more difficult as you need to turn your whole torso to get to 90.. Tilting your head left and right back and forward etc is still possible but it definately limits the back and forth and side to side motion. Which I guess it is designed to do so it is doing it’s job. I had no falls so can’t report on the protection, however It does concern me about the actual brace itself pushing into your neck and doing dameage. The best thing is it is comfortable only slightly restricts range of motion, (don’t know what chopper did wrong as he seemed to have major issues with range of motion). I did feel a bit more “safer” with it on and I guess it is a little bit of piece of mind. All in all I think it is a good investment and well worth having.
