Fitting and Maintaining cables
Home Forums Bike Preparation Tips Bike Preparation Tips Fitting and Maintaining cables
This topic contains 0 replies, has 0 voices, and was last updated by  Dean 16 years ago.
Viewing 1 post (of 1 total)
  • #98231
    Afetr Bulls near Death experiance I looked up the Venhill website and found the following recommendation good advice B)
    CABLE INSTALLATION AND MAINTENANCE RECOMMENDATIONS
    The following recommendations are given as guide to you help install and setup your cables and make
    sure you get the best from Venhill products.
    INSTALLING A NEW CABLE
    • Note the routing of the original cable.
    • Check that the overall dimensions are the same as the old one. Inner cable lengths may be
    slightly different, as the old cables will have stretched slightly over time.
    • Before installing the new cable, hold the cable upright and use a few drops of a light 3 in 1 oil to
    lubricate the inner cable. Move the inner up and down to ease the oil down the cable.
    • When the new cable is ready to be fitted, route the cable carefully and in most cases, as per the
    old cable, Make sure the cable will comfortably reach its intended connection.
    • If the original cable routing is via a heat source, make sure that there is a suitable gap between
    the cable and the heat source.
    • If cables ties are required to route the cable, leave them loose allowing the cable to move. Too
    tight and they will restrict the operation of the cable and its ability to move with the handlebars.
    • For Push-Pull / Open-Close throttle cables, always connect and adjust the pull/ open cable first
    where possible.
    • Where nipples require lubrication in levers or linkages, use a small amount of copper grease.
    Avoid using heavy greases as these will attract dirt, restrict the movement of the nipple and cause
    excessive wear and stress on the nipple and cable.
    • When the cable has been installed, check the steering lock to lock and check the operation of the
    cable at both extremes of steering. Check that the cable does not go tight and that operation is
    not impaired. If one of the above is true, check the cable routing, adjustment and that all the
    nipples are located properly.
    MAINTENANCE
    Cable maintenance is essential to prolong the life of the cable and maintain the operation of the cable.
    • MX bikes – After a race meeting or as often as possible after power washing, remove the cables
    from the bike and flush through with WD40. Keep flushing them through until the fluid runs clear.
    Once clean, lubricate the cable again with a light 3 in 1 oil and check the cable routing. Also
    lubricate nipples where required with Copper grease.
    • Trail bikes – When servicing or after power washing, remove the cables from the bike and flush
    • Road bikes – At the beginning and end of the summer, remove the cables and flush through with
    WD40. Once clean, lubricate the cable with a light 3 in 1 general purpose oil and lubricate nipples
    where required with Copper grease. Note barrel nipples must be free to rotate in the lever blade.
    Do not use heavy engine oils, chain lubricants or grease to lubricate cables as this will attract dirt,
    increase cable wear and reduce the operation of the cable. Remember: Cables are a service item and
    should be replaced at regular intervals. If you are in any doubt about replacing or installing a cable
    please consult you’re nearest qualified motorcycle mechanic.
