Fixing flats
This topic contains 15 replies, has 0 voices, and was last updated by  drew 14 years, 7 months ago.
Viewing 16 post (of 16 total)
  • #205728
    Bob Dowsett
    fresh ULP does the trick you only use it to bead a tyre really lead petrol was better
    done it heaps of times , it doesn’t always work
    you need to attach air going into the tyre through the valve and then splash ignite and dash at the same time for the hard ones
    not recommended in the shed either
    and if u don’t get it the first or second time the tyre heats up and gets harder each time and also tends to catch on fire so you have to the n put the tyre out
