Fork rebuild
This topic contains 0 replies, has 0 voices, and was last updated by  Nick 14 years, 4 months ago.
Viewing 1 post (of 1 total)
  • #100669
    Hi, does anyone have any experience of taking apart forks from a 99 RMX 250, as they do not come apart easily.
    I have got the seals and bushings out but cannot remove the inner fork tube as it is held in somehow. I think it is to do with the nut at the bottom of the fork leg. It has a clicker adjuster in the middle. The bolt just spins along with the inside. Will a rattle gun work? What do you think???
    I can replace the seals and bushings without removing the inner fork leg but would like to take it out and make sure everything is all good.
    I will try to put some pictures up soon to better explain
