Freakin electrics
Home Forums Tech Help Tech Help Freakin electrics
This topic contains 2 replies, has 0 voices, and was last updated by  Jeffrey Smith 11 years ago.
  • #104342
    Man I hate electrical problems.
    The WR450 starts and runs fine but I have no headlight or indicators and the battery doesn’t charge. I have check fuses and looked for loose connections but all seems ok.
    Any ideas?
    #260987
    You sorted yet Jeffro :huh:
    If not let me know and I can email you some wiring diagrams and trouble shooting guides for the Yammy.
    #261010
    Sorry Adam, just noticed your reply.
    Got it sorted (mostly), took it to a professional and it turns out that when I replaced the left side engine cover I didn’t tuck on of the wires to the sttor away properly and it got chewed out. Luckily it was the wire for the lights and stough and not the one to the ignition or I would have ended up stuck somewhere. All the lights are working again now.
    I also thought the battery wasn’t charging properly but it turns out the starter motor is dying and needs to be replaced but I will worry about that next time I am home.
