FREE SEX!
This topic contains 8 replies, has 0 voices, and was last updated by  john morgan 15 years, 9 months ago.
  • #98565
    now Ive got your attention……
    how often should one strip all the bits off ones bike and give it a good once over???
    IE: all the plastics,tank,guards,seat,exhaust,wheels etc.and what should one look for?
    Many thanks
    don t no Boony i am looking for free sex
    #181380
    As often as you want and look for the dirty bits ;)
    #181382
    yeah I know,,,,circle work in someones lounge room….huh,huh :blink:
    #181384
    I only do mine once or twice a year, usually if I have been on a particularly muddy ride. But then again I am lazy.
    #181386
    I have mine stripped down at the moment in preparation for the poke her and run ride in a few weeks. I too am lazy and probably should do it more often.,geez didnt I fund some crud underneath everything :X :X :X :X :X
    even took the grips off for replacement.
    #181387
    i just do it when doing a job on the bike eg change a tyre check greese wheel bearings look at brake pads check valves clearence wash moter under tank etc spose only when i haveto lazy hay
    #181388
    Give it a good spray with inox or similar around the electrics and the carby while you at it and grease all your nipples (the bike ones mate) as well.
    #181389
    john morgan
    Boony,
    my DRZ got a birthday about 2 mths ago, it was due for new chain and sprockets so I went right over it. If your already stripped her down as shown , grease everything, do your head stock bearings too. also to consider- new radiator fluid,new brake fluid,oil your cables-get a cable oiler for about 10 bucks from bike shop, if youve never done this beefore watch all the crap that comes out.
    drain the bowl of your carb to get rid of crap thats built up
