Fuel tap mod for YZs and maybe others
Home Forums Tech Help Tech Help Fuel tap mod for YZs and maybe others
This topic contains 9 replies, has 0 voices, and was last updated by  Bruce Curtis 16 years, 7 months ago.
  • #96862
    The standard fuel tap on the YZs doesn’t have a reserve position on it, the Lads over at TT told me to grab a WR250/450 one fits straight on and voilia instant reserve. However my two remaining fully functional brain cells got to thinking “:ohmy: “,”big manufacturers don’t go to the extra expense of tooling up different fittings if they don’t need too” so I took mine apart and woulda ya know, it is the same except hasn’t been machined out or a tube fitted, the outside cowl will need a little filing and I will have my multi-position tap for nothing but time in the shed.
    So there you go a bit of a small discovery for others that may have pondered the same problem.
    Bruce Cee
    #144982
    Mate I have some trick pull apart inline serviceable fuel filters for that application if you cant get onto the right tube
    #144983
    Sounds the go Mr Rat, what are they worth?
    #144985
    $12 plus postage Mate
    #144986
    reckon you may have a deal there Mr Rat, are we the only two here tonite? very quiet
    #144989
    I am used to talking to myself, its just the arguing I cant stand :laugh: :laugh: :laugh:
    #144990
    Ok did this Modification on the weekend (in amongst modding an exhaust for a mate and deciding I hate 4T exhausts) a few things to keep an eye on.
    #1-Drill the blank intake with a 5mm/5.5mm drill, if you use a 5/16-8mm you will punch thorugh the rear of the casting.
    #2-the outer cowl that has the markings on it, just die-grind/file the whole stop section away, so the tap turns 360 degrees.
    #3- a set of letter punches can be used to mark “RES” at the 12 o’clock position as this is where the tap needs to be for reserve.
    #4-5/16″ copper pipe works as a pickup with a slight flare
    And does anyone know if two part expoxy resin works in a fuel tank?
    Bruce C.
    #145336
    Bruce C.
    It should be Ok :unsure: Try Plastibond (Selleys) now that is good sh#t;)
    Nice work Bruce
    OllieB)
    #145337
    Paul Bayly
    Can’t you solder it in?
    #145925
    cast soft Alumnium, I wouldn’t be game to put any heat on it, doesn’t matter, two part resin did the trick.
