Furked Fork
Home Forums Tech Help Tech Help Furked Fork
This topic contains 8 replies, has 0 voices, and was last updated by  murph the surf 14 years, 10 months ago.
  • #99955
    Have been changing fork seals every few hundred Kms and I’m over it. :angry:
    It has just blown out again after 230kms
    Any ideas??
    I know what the problem is but its a bit of a hard fix without buying a new outer tube.
    A new outer tube will cost 800 big ones. :sick: And will be a different colour anyway.
    The problems lies with the bottom bush of the outer tube on the brake side
    Where the bush fits has worn. Have tried new bushes a couple of times but eventually (2 or 3 hundred clicks) it starts leaking again. It becomes an issue when you grab a handfull of front brake and nothing happens. :ohmy:
    Have looked at sleeving the tube but there really isn’t enough meet
    Any ideas would be appreciated
    Looks as though I’m going to have suck it in and buy a newy. :sick: :sick: :ohmy: :pinch:
    Speak with Tekniks Murph it their gig mate its what they do, cant be rechromed? Again they are the experts
    47322626 ask for Evil Rudy or Nick
    Thanks TB
    I’m about to strip the fork down now
    The plan is that I take the outer tube to work tomorrow and bore the worn area so as to make it perfectly round again (it has worn mostly on one side)
    By placing the split bush on the inner tube I should be able to measure the outside diameter
    This will be the original diameter of the bore where the bush sits
    From there I will perhaps use shim or machine a sleeve to suit
    Hope there is enough wall thickness on the tube
    Sounds like a plan
    Certainly cheaper than a new outer tube
    Will update as I go
    Has anybody had experience with aluminium Devcon or the likes??
    Was thinking of smearing some of that in the bore and machining it back to the original size.
    Went with the aluminium Devcon
    and its curing at the moment.
    I have a large halegen light on it to speed the process up as it is not the best of days to be doing this sort of thing.
    Bored the Devcon out to 52mm
    Machined a leading edge in the bore and clean it up
    Should be a goer
    If it is I have just saved myself $800+
    Murph.
    #202096
    Murph,
    I read the data sheet for Devcon and it looks the goods ;)
    It does state for industrial use only :ohmy:
    If anyone requires an industrial strength product its you :laugh:
    The ultimate Murphsberg is an industrial strength trail ride thats for sure :laugh:
    The worst that can happen is your seal will leak again, nothing ventured nothing gained :silly:
    #202221
    tim
    adam wrote:
    Murph,
    Or the fork will snap in half:pinch:
    Have you looked into buying a set of second hand one’s, A guy I work with got a set of factory White Powers from the states for less than a grand delivered, a quick look on ebay i saw a couple of sets for less than 500 delivered, not sure exactly which ones you need though
    #202240
    Sounds like you may have nailed it Murph.
    Tim may have a good option there if your keen to keep the old girl rolling for the future. If you can source same sized forks off similar years you might even be able to swap internals if you need. Forks do come up often.
    #202252
    Thanks for the vote of confidence Medogrocket. :dry: :laugh: :laugh:
    Have just finished puting it all back together and everything went smoothly.:)
    I’m quitely confident
