Home › Forums › European Rides › GasGas EC300 test
This topic contains 10 replies, has 0 voices, and was last updated by Anonymous 17 years, 1 month ago.
December 7, 2008 at 10:22 pm #95490
AnonymousOllie could answer this best I guess, but open to all opinions…
I test rode the 300 on Saturday. I liked it but was put off by one thing..
I found it didn’t cleanly progress into band. Is this normal or was it a jetting problem.?
It was under light progressive throttle when it occurred. If you gave it a handful it didn’t do it , but then you had more then you needed in power..
What do you think?Or was it my riding style:S
December 7, 2008 at 10:59 pm #114037I know Ollie’s been talking about his jetting for sometime, him and Gasser maybe can give you a heads up. Question for Ollie, once you get your jetting right, can you expect that it will be ok at most locations for most conditions for most rides?
December 8, 2008 at 1:43 am #114040JRD,The Gasser should be giving you a smooth almost 4 stroke like transistion, The power band is not as aggresive as say a KTM which has a MX type “hit”,As TB will testafy my bike just torqued up a steep slippery hill last weekend no problems at all.Im having jetting issues at the moment as I like things to be spot.My problems are in the 3/4 throttle position where it stumbles probably a bit rich on the main at the moment, usually when its right it should just be a case of adjusting the air screw when required for the different temps encountered,other than that nada.I will post later a number of different peoples jetting setups and that should give you some indication of what you should try.
if the bike you were riding was a test bike surely the dealership would have had it jetted right you would think?:unsure:
the symptoms sound like an overly rich pilot or needle position,ie as the throttle is cracked open more air is allowed to pass which inturn leans out the mixture,anyone can correct me if they think that I am wrong:unsure:cheers Ollie
07 300EC
PJ 38
MN 178
NIEG needle(leaner than stock)
#7 slide
air screw 2 turns out (atm)December 8, 2008 at 1:52 am #114038
AnonymousI will try and ride another one and confirm whether it’s the bike or me…
It just didn’t feel right.. I would have thought you could bring the revs up and bring it into band under light load without spluttering..December 8, 2008 at 2:00 am #114041yes you should it definatley sounds like a jetting issue.The way a bike responds to throttle application is a personal preference,I like to be able to torque thru the crap but also be able to snap open the throttle and get instant gratification when required
December 8, 2008 at 2:05 am #114042
AnonymousOllie wrote:
Quote:I like to be able to torque thru the crap but also be able to snap open the throttle and get instant gratification when requiredollie
I certainly wasn’t getting that and it was disappointing….
December 10, 2008 at 4:33 am #114043
AnonymousStill not got the jetting sorted then mate?
December 10, 2008 at 5:11 am #114304Moto wrote:
Quote:Still not got the jetting sorted then mate?I have just bought myself a #42 pilot jet from procycles @ $22:angry:to try, but they didnt have a 172 main which i want to trial also,might give show and go the Keihin importers a go, That should get it close to the Mark, Damn I hate being a perfectionest:laugh:
December 10, 2008 at 6:34 am #114306
AnonymousWell by the time I back in action it should be all sorted for me then :p You’ve probablt got a couple of months
December 20, 2008 at 9:14 am #114039I am running a size cek needle second clip from top 78 main 38 pilot and a norside power valve cover.I found this set up works for my riding style.this gives me a very smooth power delivery with no hesitation or spluttering at all.if you were after more aggressive top end i would be looking at a 250cc exhaust.do a lot of research before running a 172 main
December 29, 2008 at 9:36 pm #115675
AnonymousDid you get anywhere with the new jetting specs Ollie?
