Glue and/or adhesives
Home Forums Tech Help Tech Help Glue and/or adhesives
This topic contains 25 replies, has 0 voices, and was last updated by  glenn 16 years, 11 months ago.
Viewing 11 posts - 16 through 26 (of 26 total)
  • #128338
    The SC2000 glue is the go, a little trick I use when having to use it, apply the glue to both surfaces let them completely tack off and then use a heat gun to bring the temp up then push them together, Bobs your uncle, Jobs done:laugh:
    #128346
    Have tried Sikaflex on several occaisions and can tell it doesn’t work for very long. I have just used some Selleys Shoe Glue on Taylah’s boots and they seem to be holding together OK.
    #128357
    Heat activated glue is the go
    #128360
    So who can recomend something that will hold them together, as they are the most comfortable boots that I have ever had and I want to keep using them.
    Try this trick (should work)
    Drink copiuos amount of my friend (Dr tooheys or your prefered choice of grog)
    1 place foot in boot
    2 put boot with foot in it on bench (toes pointing up)
    3 ring mate with a nail gun(ramset is the prefered brand)
    4 stategicly place end of nail gun wher sole is lifting
    5 Fire
    6 Boot fixed and is still the most comfortable boots that I have ever had
    Problem solved and you are welcome:woohoo:
    #128368
    5 Fire
    Boony you are a thinking man by the looks of things.
    What should one do when the effects of the copious anmounts of VB wears off?
    How do I get KylieD to accept the fact that I will not be taking my boots off to go to bed?
    What do I do when the boots do wear out and my bones have become one with the Paslode nail?
    #128387
    easy
    Just warn KylieD shes gunna need a new man in about 6 months and alls sweet as for the other minor issues Im sure some one from this site has ideas.
    Hey I was only helping with the boot problem.;)
    #128388
    Done right the effects shouldn’t wear off
    Let her wear hers and make a game of it
    Just nail a double plugger to the bottom of the boot at any sign of wear
    #128393
    As I said before “I knew I could rely on the Old Bulls”:)
    I suppose it will put a new swing on “knocking boots” if we both wear our bike boots to bed.:kiss: 👿 :pinch: :woohoo:
    I should last longer than 6 months if I use stainless nails in the Paslode I would imagine.
    #128394
    I supose you should spare no expense on the nail. plus stainless won`t rust and pollute our waterways when you do a creek crossing, thank you for considering the enviroment:P
    #128409
    DanD wrote-
    porn stars always leave thier shoes on Dan:P :P :P
    #128428
    DanD wrote-
    sorry spidy but did you mean porn or poor star:huh:
