This topic contains 29 replies, has 0 voices, and was last updated by Nick Again 16 years, 4 months ago.
October 15, 2009 at 6:16 am #97346
I have just finished greasing the five nipples on my DRZ.
Is it good if grease comes out of the joins or is it bad because it means i have broken a seal ?
Also how the f&*k can i clean the carpet, before the wifey gets home, of grease marks i walked through the house ?
October 15, 2009 at 6:31 am #156655your gonna die JAK. :woohoo: :woohoo:
your lovely wife is gonna clean the carpet with your head :laugh: :laugh:
see you in the next world mate
ps- i dunno how to clean it….maybe some brakecleaner
October 15, 2009 at 6:47 am #156663Grease coming out of the joins is Good
Grease on the carpet is Very Bad :laugh:
easy solution go and buy a mat :laugh:
October 15, 2009 at 6:50 am #156664I’d pack the bags and head for the hills. Can’t help with the clean up maybe a bit of diluted degreaser rubbed in gently.
Just finished cleaning the house myself before the lord and master gets home from India tonight. I think I should of paid someone to come in after batching for ten days the joint was a pig styeOctober 15, 2009 at 6:53 am #156665By the way happy birthday. I don’t think you will be getting any special present with grease on the carpet. Perhaps just tie yourself to the tree out the back and await the punishment
October 15, 2009 at 6:54 am #156656JAK wrote:
Quote:Is it good if grease comes out of the joins or is it bad because it means i have broken a seal ? ]Its good as it helps flush the water/dirt out of the grease in there but it does stretch the seal, I reckon if you put a couple of pumps in after every wash or wet ride you on a good thing
Also how the f&*k can i clean the carpet, before the wifey gets home, of grease marks i walked through the house ? Run Forest Run !!
October 15, 2009 at 6:58 am #156666Trailboss wrote:
Quote:JAK wrote:Quote:Is it good if grease comes out of the joins or is it bad because it means i have broken a seal ? ]Its good as it helps flush the water/dirt out of the grease in there but it does stretch the seal, I reckon if you put a couple of pumps in after every wash or wet ride you on a good thing
At least I dont have to worry about the bike then.
I can tell you windex doesnt work on the carpet but at least now i’ve smeared it in enough that if i put the coffe table over it no-one will notice.
Coffee table didnt work. I’m gone.
October 15, 2009 at 7:05 am #156657thats why they call it DE Greaser ???????????????
Nah just joking I think it would probably be the worst thing to use
trial and error
i would use omo to do the stain and hot water after getting excess offSorry to upset the apple cart but it depends what sort of bearing or shaft u r greasing
if it was a sealed bearing or notshaft good
bearing could be good or bad ?????October 15, 2009 at 7:07 am #156670But i’m no mechanic
or Stain remover
October 15, 2009 at 7:09 am #156672They arent the sealed Brgs you are thinking of Bob, but good point
October 15, 2009 at 7:14 am #156673If it has a nipple from the factory, chances are it is s’posed to be greaes until fresh grease is spotted.
Prewash spray like “Preen” and napisan afterwards diluted in warm water with a cloth and scrubber may help you with the carpet, been there and lived to tell the tail……. but tail was sore :huh:
October 15, 2009 at 7:22 am #156674Mr Blue wrote:
Quote:If it has a nipple from the factory, chances are it is s’posed to be greaes until fresh grease is spotted.Prewash spray like “Preen” and napisan afterwards diluted in warm water with a cloth and scrubber may help you with the carpet, been there and lived to tell the tail……. but tail was sore :huh:
Thanks Mr blue i’m on to it right away. Times running out.
October 15, 2009 at 7:28 am #156658Buy some spray on carpet cleaner from supermarket, Its called orange power, spray on leave for about half a can and then dab with warm water, spray again drink other half of can dab and alls good!!! Been there done that.
PS. Rememeber to dab and not rub :dry:
If that does’nt work drink another can and blame the dog!!October 15, 2009 at 7:30 am #156677Add 5 parts petrol to 1 parts spark, remove all wanted stuff then crack a red bull and pretend to be shocked.
Or just the 5 parts petrol to the grease…October 15, 2009 at 7:36 am #156678im not one to pre-empt very often…..
:laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
sick him Nat
