guess this bike
Home Forums General Bike Talk guess this bike
This topic contains 18 replies, has 0 voices, and was last updated by  Bruce Curtis 16 years, 10 months ago.
  • #96399
    racy and i droped into a bike shop that sells these bikes
    what are they?
    #134605
    i dunno mate, but i like the little fan-ny thing-ys. i wonder if theyd spin.
    itd be good to paint them into a pyshcaladelic spiralor something!!.:laugh: :laugh:
    #134606
    my 1st guess would be Benelli, going on styling and colour schemes.
    #134607
    aaron childs
    saw something with the fanny thigies the other day
    pretty bondish 007
    parachutes?:blink:
    #134608
    Garry
    It is a Benelli Tornado (think in some markets called the Tre)- a very nice looking piece of kit that ran the same motor as the awesome looking Benelli TnT (1130cc)
    Garry
    #134617
    yea your right
    very pretty bikes
    racy reckons they look like transformers
    while we were there, we bought a hd tube for racy’s bike
    we should be able to cut knobs into this one
    #134622
    They are the best tubes, harder to fit but never ever had a flat and am still using the same one I used in 2004 when I went to the cape, been used through two bikes.
    what are they?
    i assume that the radiator is under the seat
    #134629
    yep so if you fart it over heats
    #134610
    aaron childs
    so if you s*!t yourself your f@rked
    #134624
    Benelli Make some sexy bikes and now they even have offroad bikes. Word is these are being brought into Oz by Stont Creek Power Sports.
    #134630
    that looks the horn!!!!!!
    it would look better in orangethough:laugh: :laugh: :laugh:
    #134631
    It doesn’t look bad does it :)
    Probably just me but the forks look a bit thin and the swingarm looks really chunky?
    #134661
    I love minimalist styling like that, Forks are only too thin if there is too much flex Moto, probably talking to the right bloke cause doesn’t wall thickness play a major part in strength ? ;) and the side covers/seat/radiator guards are horn as.
    Benelli made the first six cylinder motorcycle too I seem too remember, dunno if it is a continuation of the same company or just a bought name and rebirthed though.
    Bc
    #134666
    TYPE Single cylinder, 4 stroke, liquid cooled, 4 titanium valves, double overhead camshaft, with balancer shaft
    DISPLACEMENT 505 cc
    BORE x STROKE 104 x 59,5 mm
    COMPRESSION RATIO 12:1
    RATED OUTPUT 44,5 kW (60,5 CV) @ 8500 rpm
    MAX. TORQUE 50 Nm (5,1 kgm) @ 5750 rpm
    FUEL SUPPLY Electronic injection with throttle body ø44 mm
    EXHAUST SYSTEM With catalytic converter and oxigen sensor
    CERTIFICATION Euro 3
    CLUTCH Wet clutch
    GEARBOX 6 speed
    FINAL DRIVE Chain drive, ratio n.d.
    CHASSIS
    FRAME Single tube cradle with forged, casted and extruded elements and carbon structural part patented. Light alloy rear subframe
    FRONT SUSPENSION ø50 mm upside-down fork, with hydraulic extension and compression adjustments FRONT SUSPENSION STROKE 298 mm
    REAR SUSPENSION Aluminum casted swingarm, progressive rear dumper completely adjustable in extension, compression and spring preload
    REAR SUSPENSION STROKE 315 mm
    FRONT BRAKE Single floating disk ø260 mm with 2 pistons floating caliper
    REAR BRAKE Single disk ø220 mm with single piston floating caliper
    FRONT RIM 1,6”x21
    REAR RIM 2,15”x18”
    FRONT TYRE 80/100 R21
    REAR TYRE 140/80 R18
    SIZES
    LENGHT 2160 mm
    WIDHT EXCLUDING MIRRORS 810 mm
    HEIGHT EXCLUDING MIRRORS 1240 mm
    SEAT HEIGHT 960 mm
    WHEELBASE 1470 mm
    UNLADEN WEIGHT* 110 kg
    ROAD READY WEIGHT** — kg
    PERMITTED TOTAL WEIGHT — kg
    USABLE TANK VOLUME 8,5 lt
    RESERVE n.d.
