Home › Forums › Yamaha Bikes › Yamaha Bikes › Hand Operated Rear Brake
This topic contains 6 replies, has 0 voices, and was last updated by shane 17 years, 4 months ago.
November 14, 2008 at 5:14 am #95373
AnonymousWhen I installed the Rekluse autoclutch on my wr450f, I didn’t purchase the external clutch adjuster, which utilises the existing clutch lever mechanism. This being the case, I was able to completely remove the lever, bracket and clutch cable, as they aren’t used anymore with my Rekluse configuration. ie, I don’t have a clutch over-ride setup. Note that other brand bikes that have hydraulic clutch actuation, can still use this setup as an over-ride for the Rekluse.
I had read elsewhere that it was possible to install a hand operated rear brake, as opposed to using the footbrake lever. This in theory, would allow you to brakeslide into corners bothways, whilst extending the leg forward for balance, weight transfer etc. With a footbrake, you can really only perform this into left hand turns. The handbrake also allows much better feel of the rear brake, than than offered by a foot in a big leather boot.
The solution required sourcing a master cylinder for the lhs of the bars. The answer is a clutch master cylinder. The problem with this selection is that the seals in this style of cylinder are designed for mineral based hydraulic oil and not glycol-based brake fluids. Brake fluid destroys the seals. The way around this is to use DOT 5 silicone based brake fluid.
I removed the foot lever and master cylinder and existing rear brake line from the frame. I then had a custom made s/s braided line made up with suitable fittings for the slave cylinder and the Maugura clutch master cylinder that I ended up using for this project. I routed the new brake line in and along the frame to the rear slave cylinder, taking care to keeping it away from the exhaust system. In places where it was a bit close, I wrapped the line in some heat reflective tape.
DOT 5 and other glycol-based DOT 4 fluids are NOT compatible. It is extremely important to flush out the system before using the new modified brake setup. I used metho to do the initial flush, followed by forcing through some silicone fluid. Trying to get the fluid into an empty line and cylinders was a prick of a job. I thought it would simply be a case of pouring the fluid into the master cylinder resevoir and just keep pumping and topping it up, until it came out of the bleed nipple on the slave cylinder. WRONG!!
I conservatively say that I spent 90 mins trying to do it by this method with no success. I eventually put a length of clear plastic tube on the slave cylinder nipple, and physically sucked on the tube until the fluid was visibly coming through the nipple. Once I was happy that I had flushed the system, it was simply a matter of bleeding the brakes as normal, until a firm lever pressure was attained.
I am by no means a “gun” rider nor have done much riding with the new setup, but the rear brake has good “feel” and the rear tyre can be locked if required using just two fingers. It did take some getting used to initially, as one tends to grab a handful of clutch when downshifting a couple of gears. It becomes just like riding a pushbike with both brake levers on the bars.
I made a small bracket so I could still utilise part of the original clutch lever bracket to mount the hotstart lever
WARNING If you regularly ride a road going bike, I highly suggest that you DON’T do this modification. This is because of the possibility of getting used to not using the foot lever etc.The costs involved were as follows:
Magura clutch master cylinder – $220
Custom made brake line with fittings – $125
500ml bottle Shell DOT 5 silicon fluid -$22Down the track, I am looking to figure out how to have both the brake and a clutch over-ride lever on the bars.
Here are some pics of the setup, but I will get some more of the brakeline and stuff later.
You can see in this pic where I mount one of my tyre levers
November 14, 2008 at 5:25 am #112150Man you must do a lot of standing in your shed scratching your chin!!! Great post Nigel.
November 14, 2008 at 5:36 am #112153
Anonymousmicknmeld wrote:
Quote:Man you must do a lot of standing in your shed scratching your chin!!!Not really Mick, but I do spend a lot of time lying on the couch watching the telly and scratching my nuts.
November 14, 2008 at 12:11 pm #112154slug wrote:
Quote:micknmeld wrote:Quote:Man you must do a lot of standing in your shed scratching your chin!!!Not really Mick, but I do spend a lot of time lying on the couch watching the telly and scratching my nuts.
Waaaaayyyy too much information!
I did see a setup, probably on Porky Eldridge’s bike a long time ago, where he had both brake systems running on the one lever. No recluses back then my friend! I thought that would be wierd to ride…now I’ve seen this,
November 14, 2008 at 12:24 pm #112188shane_vor wrote:
Quote:I did see a setup, probably on Porky Eldridge’s bike a long time ago, where he had both brake systems running on the one lever. No recluses back then my friend! I thought that would be wierd to ride…now I’ve seen this,
You may wish to explain for the punters why Porky had that setup,I know am sure you do but I bet many dont
November 14, 2008 at 1:33 pm #112189Porky is a legend and he rides a smoker, which makes him a double legend, and I unlike others do not use the term legend as a throwaway.
had a nasty off last year or year before too didn’t he?Mr Blue
November 14, 2008 at 10:33 pm #112190I have only ridden with him twice. The first time when I was much less grey and much more naive, I thought to self, “Yeah I’m pretty fit and can handle a bike. I reckon I’ve got this bloke’s measure.”
Result: less that two corners later I can’t even see the man’s dust.
I thanked my lucky stars that day that I didn’t verbalise my cockyness! I learnt a valuable lesson that day my friends, never judge a book by it’s cover and to keep one’s gob shut tight. To this day I still don’t say much out loud.
To explain, Mr. Eldridge’s right foot/leg, is artificial.
Legend? I don’t know enough about the man to tag him a legend, but from what I’ve seen I can understand why the label might be attached.
Oh! And I should add that I wholeheartedly endorse his bum bags. They are the shiznit!
