Home › Forums › Do It Yourself Videos, Photo Posts Helpful Hints › Do It Yourself Videos, Photo Posts Helpful Hints › HD Video Tips,Tricks and Questions
This topic contains 33 replies, has 0 voices, and was last updated by Nathan Heather 12 years, 4 months ago.
March 27, 2012 at 9:30 pm #218894
Also can i just upload straight to this site as a file attachment and is it quicker?
March 27, 2012 at 9:49 pm #218898Nato wrote:Also can i just upload straight to this site as a file attachment and is it quicker?No mate, a we aren’t hosting all the videos as it would cost OBT a small fortune and b we aren’t setup for it anyway :laugh:
Sorry Nate YouTube is your friend, dumb the footage down like The King says no difference at 720 here on your LCD TV but it’s a huge difference
April 25, 2012 at 12:34 am #218899This worth buying? Im sick of downloading the freebies
April 25, 2012 at 1:19 am #220485Studio is good stuff mate. Just google that this version is HD (1080p) compatible and if so do it.
May 26, 2012 at 9:37 pm #215562On a recent ride I lost my GoPro in the bush. Normally whenever I feel it hit something I reach up to check but on this occasion I had not hit any branches but it was gone. On close inspection the mount had cracked and released the camera. As hard as Corey, Nick and myself tried to find it, it was gone.
New GoPro arrived this week and I have made a tether for it so this cannot happen again.
My helmet (Fox V2) has front ports that a small cable tie can fit through perfectly. I used this as the base anchor point and then tied up some strong cord the way you do to hold your leg rope to your board.
I looped the camera through that and secured the other end to the hinge pin on the back of the GoPro housing.
I also mounted the optional rubber bracket plug (white insert) so it can not release accidentally.To remove the camera I have just enough slack so that I cant feed the camera back through the loop in the leash when I want to remove it and all I am left with is the standard mount and a small cable tie through he vent.
Hopefully saves some one else from an unnecessarily expensive trail ride.
May 26, 2012 at 9:45 pm #222673Another thing I forgot to mention and have learnt the hard way that the GoPro mounting brackets become brittle over time. Mine had been on there for two years so I suggest replacing the mount every year as they are exposed and do take a beating.
July 12, 2012 at 9:13 pm #222674Thanks for that. I Will be doing something to mine also.
July 23, 2012 at 1:45 pm #226012Scotty, you might want to run the cord with a little more slack so you can stick it to your helmet. With the current way it’s set-up you have a big hole a branch or lantana can poke through and pull your head off! If you ran the cord taped to the helmet and a loose zip tie around the cord where it’s next to the camera base you would reduce the chances of it getting snagged.
Good idea though, you don’t want to be losing HD camera’s every couple of months!
What video editing software do you run on the Mac?
July 23, 2012 at 5:10 pm #226504moto wrote:Scotty, you might want to run the cord with a little more slack so you can stick it to your helmet. With the current way it’s set-up you have a big hole a branch or lantana can poke through and pull your head off! If you ran the cord taped to the helmet and a loose zip tie around the cord where it’s next to the camera base you would reduce the chances of it getting snagged.Good idea though, you don’t want to be losing HD camera’s every couple of months!
iMovie is preinstalled and is a great basic editor.
August 7, 2013 at 11:56 am #215563Getting smooth slow motion can seem like a black art so I put together a tutorial that I hope can help a few out.
http://www.youtube.com/watch?v=m4WOHMYbe_w&feature=youtu.beSTM
September 18, 2013 at 12:51 am #215564For the Contour Roam fans Torpedo7 has a good 48 hour deal on.
http://www.torpedo7.com.au/division/motocross/picklist/3554
September 19, 2013 at 9:21 am #249903STM put me onto things called moisture strips…..
They go in either side of the housing next to your camra…
on all reports they are a good thing…I will be trying mine for the first time soon….…spud…
October 30, 2013 at 6:09 am #215565In the quest to get the best possible images out of my GoPro I did an experiment. The results speak for themselves.
http://www.youtube.com/watch?v=fomX85O6cHw&feature=youtu.be
October 30, 2013 at 6:14 am #215566Spud I can honestly say they work
I use them all the time
You can even dry them out in the oven and re use them although I confess I haven’t done this yetOctober 30, 2013 at 6:24 am #251180Your a legend STM.
Been thinking I should get a GoPro. But my Drift is doing fine. -
