Heated Grips Group Buy.
Home Forums Current Sponsor Deals Current Sponsor Deals Heated Grips Group Buy.
This topic contains 99 replies, has 0 voices, and was last updated by  glenn 16 years, 8 months ago.
Viewing 10 posts - 91 through 100 (of 100 total)
  • #137775
    Anyone got their Heated Grips installed & running yet ????
    I`m doin` mine say arvo (I hope:dry: )
    #142138
    Say what arvo Beagle?? :laugh: :laugh: :laugh:
    my new grip warmers turned up today,and there easy to fit Don`t know what the fuss is all about.. Luoti_gloves.jpg
    #137776
    Peter W
    I have been told that if you spray some of this on your hands you will have no problems!
    Im gunna give it a try and if it doesn’t work I will purchase some grip heaters :laugh:
    #137777
    Pads & new grips are on, switch bkt made and wiring is half run & clipped to the bars;)
    Just wanna confirm which wire to connect the other end to get 12v from the light tomorrow after soccer & she will be WARM HANDS on the way to work Monday morn:) :) :)
    Installation is a piece of cake, probably 1.5hrs total
    Thanks again to Mal at Sutto`s for the great deal & productB)
    #142231
    A bit worried about wiring to the light,,,,
    I will attach to something else (ignition etc)
    Any suggestions????
    #142235
    Any suggestions????
    #137778
    Thanx Boon ( I think NOT) :P
    You have NO IDEA ,, Do Ya ?????:laugh:
    #142236
    your dead right ,,,I haven`t got a clue:(
    #137779
    Now have em wired up, working and yes the hands are nice & warm;)
    Left it running on the low setting for a solid 5 mins before the left grip heated enough to notice with bare hands (would have been good to insulate the bar first , as a lot of the heat is transferred into the bars first:huh: ) The throttle tube, being plastic, is almost instantaneous warmth:) :) :)
    I have temporarily wired the power lead straight from the battery at present, till I am 100 % happy with the test ride on Monday,,,, I also need to get to work to use the heat gun to shrink all the heatshrink on the cable connections etc;)
    One point to note is , the positioning on the WHITE RESISTOR, as it gets F@%#&*@G HOT:blink: So be careful to keep it away from other importatnt cables & plastic parts!!!
    Mine is cable tied to a small steel bar on the bottom of the headlight assembly, where it will also get tonnes of fresh cool air whilst on the move ;)
    So FAR, Very Happy indeed:woohoo:
    Good Luck All
