Helicoil vs Time sert
Home Forums Tech Help Tech Help Helicoil vs Time sert
This topic contains 18 replies, has 0 voices, and was last updated by  Alex 12 years, 6 months ago.
  • #103051
    After a bit of interest in this subject on my crf450 thread I thought it could be helpful to start a new thread on just this subject.
    I’m sure Teknik will put in some great advice to help us all ;)
    Here’s a video ( done by Stephen Hawkins it sounds like :D ) on Time serts
    http://youtu.be/anjDQJtWFc8
    Installing a Helicoil
    http://youtu.be/RFYa6sjhh_E
    Time sert kit
    About $150 for this kit ( does one size only)
    #246945
    Heli coil kit
    About $120 for this kit ( does multiple threads )
    #246946
    Nickj wrote:
    Heli coil kit
    Don’t want to sound difficult but that isn’t a genuine helicoil kit and some from experience the cheaper kits are crap, the coils break and you end up in my trouble than you started in. The threads break, arent made from stainless, the tags snap before the thread is seated. The genuine kits are more expensive
    Just saying
    Great thread Jacko,,
    I have used Helicoils many times in various applications in the past and they are pretty solid ;)
    Never heard of the Timeserts ,, but it is always good to have more options …
    Nick is right the Time-serts are way more solid, dont pull out like a helicoil can and does every now and again , you can back it out if you have a problem on installation and are stronger again.
    Nickj wrote:
    Heli coil kit
    Just saying
    Great point TB , I was just searching for a picture example and this came up , good to know their are some cheaper sub standard copies out there !!
    This is a better quality bike specific kit for M6 and M8 bolts and valued at $178
    #246985
    Hey Nick
    We use Helicoils (brand name) at work.
    Never had a problem, never really had to use them very often.
    (probably less than 6 times over my whole time as a fitter, 32 years)
    Good luck with what ever you decide on doing. :unsure: 😆 :blink:
    I have used the helicoil branded ones for a long time in my workshop and have found them easy to fit and extra strong.
    Have used them heaps in alloy chainsaw engines. The only negative I found was sometimes when you are removing a bolt were a coil has been used the coil can wind out as well.
    There are a lot of different ones on the market I also find that the size you have to drill out to fit the coil with helicoils is only minimal.
    Just my opinion
    Robert
    #247002
    Nick Dole
    Hey, a fastners thread, i’m in love!
    This is my helicoil selection. There are a few brands but we can lump them all into one basket, wound stainless steel inserts.
    #247004
    Nick Dole
    You can see from that last photo there are 3 different depths of coils, 1D, 2D and 3D. The Std 1D are 1x the thread diameter in length. In most cases that’s all the thread you need.
    However in high load situations you may need 2D and 3D.
    You can also see the solid inserts, the timesert brass looking sparkplug inserts and the pre loctited Loc sert for when helicoils are stripped out
    #247006
    Nick Dole
    Now you can see the issue with helicoils, they are just a spring you wind into an oversize tapped hole.
    1. Loctite won’t hold them in, it’s an anaerobic sealant (needs absence of air to dry) The gaps won’t let it go off when you fit it. So you wind your bolt in and the loctite gets on your bolt, then it dries. The next time you pull it out the insert comes out too.
    2. You need to be careful not to skip a thread when you install it, especially if it’s not a deep hole, the tap will stop cutting before the bottom and the insert will jump. Then you wind the bolt in and cross thread it at the bottom. Awesome to take out. Not.
    #247010
    Nick Dole
    This is a spark plug repair time sert. It’s a solid thread that uses a broach to expand the insert into the threads, mechanically locking it into place PLUS threadlock will dry in it too AND if you need to remove it a little heat and an EASY OUT will get it out with no damage to the parent thread.
