help smokin xr600
Home Forums Tech Help Tech Help help smokin xr600
This topic contains 7 replies, has 0 voices, and was last updated by  anthony 16 years, 3 months ago.
  • #97694
    anthony
    gday guyz n gals,had a few problems with my 98 xr 600,i went through what i thought to be
    a shallow rut.turned out deeper than the murray river,when i got out the bike coughed farted and carried on.cruising at 110kmh it would cut out like it was flooding.i look down and theres a heap of fuel pissin out.think the carby need a clean?
    next up we have smoke blue in colour coming from exhaust i think its only when slowing down,i look back under power and it seems to be smoke free plz help tired of this smoke :huh: :S
    cheers all glow!!!
    #164433
    anthony
    its a lil smoky at idle too
    #164434
    going off your symptoms glow, I would say valve guides and or rings. you may need to do a compression check.
    oh yeah almost forgot,pull your carb out and give her a good clean,check your float height,choke plate and jets 3 beer job ;)
    #164438
    anthony
    thanks ollie but if it were rings wouldnt it blow smoke on the throttle?
    #164439
    depends how far gone they are, compression check will confirm it for you mate. Mick or TB should be able to confirm it for you as they are XR heads B)
    OLLIE
    #164440
    anthony
    cheers ollie,carbs been out and cleaned its back in running no probs still smokey tho.
    #164442
    Probably valve guides and seals, will PM you my mobile number as there are way to many variables to a decision here, you can post up what you find and why later if that helps
    There are also a couple of ways using a compression gauge to confirm if its valves and guides or rings
    anthony
    thanks boss i’ll call you tomorrow :)
