This topic contains 72 replies, has 0 voices, and was last updated by Adrian Snowden 13 years, 7 months ago.
May 15, 2011 at 8:32 pm #201317
Carry a spare clutch lever, a front brake you do without, clutch lever less so.
Spare chain joining link on front brake cable, oldy but a goody for everyone else but me.
May 15, 2011 at 8:51 pm #201282Sparkplug spanner fitted to broken ktm400 clutch lever (hey Justo)
Yep, That was a good save Hatto:lol: …. Lesson learned I now carry a spare lever:ohmy:
May 15, 2011 at 9:01 pm #201283Spare brake and clutch levers cable tied inside airbox.
KTM not sure on other models if they will fit.
Looks like enough space for a spare gear lever as well.
May 15, 2011 at 9:09 pm #201322I use a lot of garden hose to stop vibrating noises on my bike, between frame and bash plate, under bark buster mounts. My front guard rubs on the bottom radiator hose between the 2 rads so it copped some garden hose too (the guard is from a later model bike and is bent and snapped)
May 15, 2011 at 9:46 pm #201323Always carrying a spare tube, tyre levers and a spanner that will get your wheel off is a good idea too, that way your ride doesn’t get held up for an hour trying to find a spanner.
May 15, 2011 at 9:47 pm #201284I like to oil my air filter in a plastic bag:cheer: and if possible try and ride with a fitter and turner cause they can fix just about anything:laugh:
May 15, 2011 at 10:15 pm #201285Most of my tips are last century.
Tin cans are good to braze on rusted out 2 stoke muflers.
Use the oxy to burn out the carbon on a 2 stoke muffler.
Strips of tin cut and placed around the rounded side of a drum brake pad gets a bit more life out of them.
Make sure sure the slit on the clutch/brake lever adjuster is pointing down to lessen the chance of moisture getting in the cable.
May 15, 2011 at 11:27 pm #201327If you have to add oil straight into your fuel tank,make sure to turn your tap off and tilt your bike so the oil will run down to the non fuel tap side. Young bloke at Dungog on a YZ250 didnt do this and wasted an hour of our riding time diagnosing pulling carb apart etc ! :angry:
In a pinch a piece of aluminium can, can be shaped into a reed petal :woohoo: saw it done on a KTM495 :laugh: worked so well he left it in there for 18 months :laugh: (this should be in the Mcguyver thread ) 😆
Drill your valve stem hole slightly larger than the stem and run the lock nut to the top under the cap, if the tyre slips it wont rip your valve stem out.
Put dabs of Silicon on your alloy subframe where the seat base rubs (remove silicon before selling your bike )
stops the subframe wearing and lookin uglyBlow the shit factory grease out of your wheel bearings with compressed air,repack with a known quality grease,get much better life out of your bearings.
May 16, 2011 at 1:32 am #201286Just thought I would add to Ollies statement. Grease your linkage bearings before they rust and sieze. And when cleaning linkage bearings with compressed air and solvent the pressure can blow apart the nylon bearing casings. So you need to buy new ones. :blush: :angry: So be careful.
May 16, 2011 at 1:58 am #201372Forget gumption or anything else to clean the crud out of your plastics, CHUX MAGIC ERASERS are the best ever, try them they work a treat and better than anything else I have used.
May 26, 2011 at 10:32 am #201300Old Berocca canisters make an excellent storage space for nuts, bolts, spare plugs etc.
They store easily in a bum bag or tool roll and are waterproof.STM
May 26, 2011 at 2:00 pm #201980A good heat gun should be in every dirtbikers shed.
used carefully they can restore plastics, both scratches and colour fade
for 2T bloke(ettes) this very same heat gun is the BEST way of burning your pipes out, real fireworks stuff without damage or risk of damage to pipes including nickel plated ones.
and they are very helpful for applying stickers and fitting tyres with stiff sidewalls in winter as well.
So heat guns ladies and gentlemen is todays handy hint.
May 26, 2011 at 2:07 pm #2012871 – Carry a little sachet of mcdonalds pepper – perfect for radiator repairs on the go
2 – Paw Paw cream (the stuff in the little red tube) prevents monkey butt, and blisters if applied before a ride
3 – A tube of quicksteel is ideal for repairs on the go, it can be used for broken cases, radiators and even joining broken levers back together
4 – Fill your camelback with water and 1/2 cup of sugar between rides, it prevents your camelback tasting like arse if you have a month between rides
May 26, 2011 at 2:47 pm #201987osmooian wrote:1 – Carry a little sachet of mcdonalds pepper – perfect for radiator repairs on the goThis needs further explanation. Pepper?
May 26, 2011 at 3:24 pm #201288Dont carry 2 tubes on a ride, Just carry a 21″ front. You can always stuff a 21″ tube into a 17″/18″/19″ rear.
