This topic contains 14 replies, has 0 voices, and was last updated by scott bocking 12 years, 7 months ago.
July 30, 2013 at 8:02 am #103073
Could someone please tell me the correct procedure for stripping down and re- greasing my linkage , I did it a long time ago but can’t remember what I did :blush:
I’ve heard plenty of stories of needle bearings rolling around the garage floor and would like to avoid this of possible
Thanks in advance
July 30, 2013 at 8:12 am #247285Nickj wrote:Could someone please tell me the correct procedure for stripping down and re- greasing my linkage , I did it a long time ago but can’t remember what I did :blush:I’ve heard plenty of stories of needle bearings rolling around the garage floor and would like to avoid this of possible
Thanks in advance
You’ll be right Nick it’s like riding a bike champ!
Just put a big magnet under it before you tear her apart mate…. :unsure: Just to catch all the needles :silly:Good Luck,
Lefty
July 30, 2013 at 8:32 am #247289If the needles are falling out technically the bearings are rooted or our riding a Chinese pit bike. See in the pictures attached the bearings are retained in the ends of the carriers
Also important is the seals if they are no good you may as well pack the bearings with dirt
July 30, 2013 at 8:44 am #247295So how often would you suggest to pull the bolts and grease ?
Is their any preferred sequence to remove the bolts ? All or one at a time ?
July 30, 2013 at 8:53 am #247286pds nick :laugh: :laugh: it works
July 30, 2013 at 8:55 am #247298Nickj wrote:So how often would you suggest to pull the bolts and grease ?Depends on the quality of the grease you use how often you ride t, where you ride it etc etc
Depends on the bike, how you have it supported. All is better and do it on the bench
July 30, 2013 at 9:01 am #247300Trailboss wrote:Nickj wrote:So how often would you suggest to pull the bolts and grease ?Depends on the quality of the grease you use how often you ride t, where you ride it etc etc
Link just went to YouTube homepage mate , what was it ?
July 30, 2013 at 9:09 am #247299Oh wow, Nick.
KTM don’t have that problem. :pinch:
Just replaced the Heim joint in my 500
It took 6000kms before it was time to change it. :whistle:
Did have the swing arm off to do said Hiem joint.
Did loose the roller bearings when tapping in the new Hiem Joint.
Bloody little needles everywhere. :pinch: :angry:
Might be time to change the swing arm bearings, I guess??? :huh:
I think I got most back in. :woohoo: :whistle: :pinch:
Sorry, Nick
I guess this doesn’t help you much.
It may help other Kato rideres though
MurphJuly 30, 2013 at 9:13 am #247304If your posts disappear and it in the tech thread here is why
July 30, 2013 at 9:23 am #247306I am pretty anal with this one Jacko and i do it quite often. There are end cap seals on both sides so i just remove one end and face that up. That now eliminates most of the risk of dropping a needle. Get a bit of paper towel and some metho and roll your finger around inside. Remove it gently so as not to dislodge a needle. Replace that end seal turn it up the other way, remove the other one and repeat. Then get a finger full of blue grease and pack that bad boy. Reassemble and then tackle the other one in the same fashion. Get them so full of grease that you can only just put it all back together and torque it to spec.
Now ride through a North Coast bog hole in the knowledge that you are as protected as you can be.STM
July 30, 2013 at 9:24 am #247307Here’s a good How to on linkage maintenance !!
July 30, 2013 at 9:24 am #247308July 30, 2013 at 9:27 am #247310Thanks for the info guys , a job I’ll tackle tomorrow
July 30, 2013 at 9:27 am #247311Nickj wrote:Here’s a good How to on linkage maintenance !!Nick
Yes like I said don’t hit them with a hammer :laugh: You can also use a vice or best a press. Be careful you don’t damage the bearings by applying to much pressure because it folds the end of the bearing cage into the rollers
July 30, 2013 at 10:07 am #247312WTF thought this was a piss take.Went and bought a press not to long ago to do this tedious shit ass job.Made it a rule to install grease nipples to most moving parts,hook on grease gun pump up n ride.
But if you have to replace bearings,once you have taken all the skin off your fingers n knuckle’s
removing the old ones,
Place new bearings in the freezer for a few hours,they will then fit straight in,not much swearing,hitting,,,,presing required. -
