How to re-build / re-bush your Pivot Pegz
This topic contains 9 replies, has 0 voices, and was last updated by  Greg 15 years, 4 months ago.
  • #98970
    Well as the title says here is how to re-bush your Pivot Pegz. Since I made the video I have discovered that they have in fact done more then 18,000kms. What would I do different? I would pull them apart and grease the more often to tell the truth, its very easy as you can see ;) Sorry about the camera work its not perfect and hard when you are on you’re own
    Parts needed, a rebuild kit which includes, split pins, washers, nuts and bushes. I also purchased a bush removal and installation tool which makes life so easy
    http://www.youtube.com/watch?v=ETwWnc-JLZQ
    http://www.youtube.com/watch?v=ABl6a0Enfvg
    http://www.youtube.com/watch?v=4K0IRfG180I
    http://www.youtube.com/watch?v=Ug_wiz6nqqA
    Nothing wrong with that camera work TB , think I’ll be greasing mine soon !!
    #187696
    Bravo!!!!
    #187699
    Good work mate, I spose I better give mine a service too, considering I have had the new bush kit for near on a year. :blush:
    #187697
    tim
    if you buy the overhaul kit direct, they now throw in the tool
    Also make sure you service them as the shaft can not be purchased separately
    #187715
    Yeah the kit you had to have at the time :laugh: :P and its the same one I got you when I got mine :blush: So I sat on mine to long Mick :blush: Saving grace for you could be that yours are not as old as mine ;) Get it done easy money.
    Yeah we both got the tool with ours Medogrocket ;)
    Great job as always TB. You have inspied me to grease mine up.
    I love your work bench. lets hope the ants don’t get into it :laugh:
    Aaron Wilde
    Great Vid TB. I Got a set of what I thought were Pivot Pegz ages ago.I got them second hand because a guy tried them but could not get used to them on a MX track. They look sort of the same. But no writing on them. ?Mk1. I took mine off and greased them about 6mths ago. I put the same o rings back in.Yes they were not in top condition but they are still sort of working. But after watching this I will try to get some sort of kit to service them properly. The nut looked more lile a nylock nut not a specially knurled one.
    #190628
    Glad it helped Aaron. I am going to try and do more DIY videos in the future
    Good job TB, I better have a look at mine!! :blush:
