how to wheelie
Home Forums General Bike Talk how to wheelie
This topic contains 95 replies, has 0 voices, and was last updated by  dennis da menace 16 years, 2 months ago.
Viewing 15 posts - 31 through 45 (of 96 total)
  • #160812
    Uncle Fester wrote:
    remember that wheelies are hard on chains and sprockets.
    How do you figure Fester? Why is it any different to just riding your bike?
    Try this there has been some ripper advice from everyone but to see it may help and maybe clearer then reading it
    http://www.youtube.com/watch?v=lUOe76YPY7M
    I rode for years and couldn’t do a wheelie of any distance but it sort of changed when I got big bore four strokes and it sort of clicked
    Practice and patience
    WR450 the wheel stand bike (except for XR650’s) just crack the throttle and it will all happen for you. Start small and get bigger.
    I love doing wheelies they are just the poo. Except for when you get wheelied on hey TB.
    #160823
    Get got to watch out for that, my bad :laugh: cant beat cracking a huge wheelie and I love it when the wheelie mood takes over and watching you and factory phil wheel stand my bike. My favorite wheelie was the one with Mick and Moose on the Crescent Head ride
    I then saw one of the longest wheelies I have seen,TB cracked a beauty that had to go a good kilometer at speed!!!!!!
    And Phil can wheel stand anything as we saw on a borrowed bike out on a private mine access rd in SA
    http://www.youtube.com/watch?v=BFn7XmVccjg
    Cant beat a good wheelie
    TB is right big bore XR’s certainly lend themselves to wheelstanding. I used to wheelstand my XR630 all the time untill I flipped it and dusted myself up a bit. Now I am a bit hesitant, I seem to have lost my nerve a bit and dont pull long balance point wheelies as often on the 650.
    Getting the feel of “balance point” is necessary if you want to change gears on the back wheel,which you will need to do if you intend to pull a wheelie for any distance.
    I always sit down and wheelie and have never really mastered stand up ones.I have seen some great stand up wheelies but one of the best wheelies I have seen on a ride was TB on the fiddy at Kempsey.It went on and on and we would have had to been doing over 100kmh.
    #160827
    I feel that I have more control when pulling a stand up wheelie. Plus they look cooler IMO.
    Moto liked the one that I pulled past him on the first Teralba to nowhere ride, I blasted past him on the back wheel standing up like he was standing still. :) I think that was around 80-100km/h. I will stop now its starting to sound like a pissing contest.
    But TB wins the prize for best wheel stands ever. I have seen him pull some colosal ones, going around corners and everything. TB’s fiddy was built to pull massive wheelies, it has so much torque.
    #160828
    Yeah that was cracker Mick as I had started in 2nd gear and ended in top gear ;)
    I also like the night wheelie watching your light in the trees
    http://www.youtube.com/watch?v=ZvtH4oTIyVE
    Always dress for the wheelie :ohmy: :laugh:
    http://www.youtube.com/watch?v=vtl4-Okbid0
    I miss riding my bike :( :(
    Ok being seious here Mono practice- low speed
    Small-midsized 4T= second gear sitting as someone said arms reasonably straight, right foot covering brake (should be anyway) constant speed at about just over idle, keeping throttle constant quickly “feather” the clutch, it will lift, now back off and get used to doing this for a bit. As you get used to lifting it start to use the throttle to control the mono, it will develope from here. If you start to go over backwards never panic you CAN pull it back easy even if the guard is scraping by usually just backing the throttle off or/and tapping the rear brake, don’t panic and bail I have snapped rear guards and not come undone.
    Big 4T= similar but usually don’t need the clutch just (if acc pump and carby response is ok) sharply apply throttle, jerk back on the bars a little and slide towards rear of bike, big 4Ts’ are a cinch to do this on, it’s almost cheating, big 4Ts usally like to sit around 60 degrees not vertical, use the power to hover.
    250+ 2T= 2nd gear sharply apply throttle at around 1/4 to 1/3 revs, and be ready for it to come up real quick as the revs rise, rear brake is more crucial obviously and you may run out of revs quicker.
    80cc-200cc 2T= similar to 250 but more revs are needed on board and is harder to control, anyone who can vert mono a 125 through the gears is a one wheeled god.
    Higher speed
    usuall clutch work or pure power, anyone can do high speed monos, but if it comes unstuck the results can be nasty as;
    My advice is to practice 2nd/third gears before gaining the confidence to react to high speed ones.
    Walking speed
    all about balance and throttle control, usually the most difficult and easiest to bugger up, most impressive to watch and a thrill to master, no where as many revs needed it’s about body position weighting and initail lift, after that it’s all balance, at the moment leave these alone and get the others right.
    Bruce
    #160829
    Ouch that last video was nasty!
    I’ve gone from being intimated riding my 450 the day I got it 16 months ago to being able to pull some alright wheelies.
    KTMrat seemed to have covered the technique pretty well and you’d do well to follow his advice.
    I started in a flat grassy field cracking the throttle in first gear and pulling up on the bars. I did this a few times and got it consistently higher before progressing to second gear.
    At this point I wasn’t really wheelying, more popping the front wheel up. Very quickly after that I progressed to opening the throttle more with the wheel in the air to prolong it from dropping down. I could do this for 20 metres or so but hadn’t mastered the balance point.
    When you get confident doing this you can start to push the front wheel higher up. i do it by popping the clutch with some revs. When you find he balance point it will be the turning point for wheelying. Once there you can just blip the throttle to maintain front wheel height and keep going for ages.
    I have recently learnt to change gear which allows me to do longer wheelies now. I don’t cover my rear brake (ever) when wheelying so I have to be a bit careful at just how far back I go.
    On a good go now I can pop it up in 3rd gear at 40K’s and got through 4th and into 5th. I’ve seen my speedo hit 123Km/h when dropping the wheel down in 5th gear!
    The next thing is to wheelie round corners, I have done this a few times but it is hard. I can hang both legs off though which looks pretty funny :P
    Get out there and practice mate!
    #160863
    This doesnt need words
    http://www.youtube.com/watch?v=6aMmaUGER9g
    Glenn
    Hey i know how to wheelie, check out my avatar
    #160874
    WTF :ohmy: Thats wrong :ohmy:
    How why and where?
    Glenn
    Buledelah last year,i was riding sweep for a mate so no one else seen it happen, high speed gravel road clicked into fourth and threw it away, anyone else got good arse pics ?
    #160877
    Geez, looks like a nice off there flapper. Welcome to OBT too :)
    Hopefully you crash and hurt another part of your body soon as I’m not sure how long I want to see your arse staring at me :laugh:
    #160880
    See Boony and Beagle
    :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
