Husaberg 2 strokes for 2011
Home Forums General Bike Talk Husaberg 2 strokes for 2011
This topic contains 23 replies, has 0 voices, and was last updated by  Damo 15 years, 8 months ago.
Viewing 15 posts - 1 through 15 (of 24 total)
  • #98695
    Just surfing around on Sutto’s web page and came across this
    Should be a good thing for those 2 stroke Kato lovers that are sick of the Puke Orange color :laugh: Very nice B)
    http://www.suttosmc.com.au/displaytest.asp?ID=747
    #183284
    Bill
    I was reading about these a few months ago but it was only a rumour then.
    #183288
    like the price olli 1 cent each whats the go change its colour and give it another name
    #183299
    Is it me or does it look like a KTM with blue plastics?
    #183300
    apparently there is also a few improvements as well
    #183301
    Pretty close Id say, It does look good tho
    Ollie :laugh:
    #183302
    At least it’s not orange.
    Looks ok.
    Wonder if it will be fuel injected. That may make me change teams.
    #183305
    Looks ok.
    PDS Mal PDS :(
    #183306
    whats wrong with the personal dismount system on a ktm TB you got to get of somehow you should try it someday. its all fun
    #183285
    i kinda sorta want one…. :dry: :) :laugh:
    interested to know the ‘husaberg’ changes that are made?? :P
    #183315
    when i herd about them thought they might have a posty style moter but no just a blue ktm(the post man likes them postys so they must be okay)
    #183316
    xy-transit wrote:
    Bugger. I thought they might have done something way out there, but it seems like it’s a blue KTM.
    Maybe one of the great guys a Suttos could get on here and tell us the differences. I’m sure there are some.
    #183325
    well i was confused is says ‘Engine Management System : Kokusan ‘
    so i googled Keihin PWK 36S AG and got listings for kato 250 exc etc. and as far as i know they’re not efi yet….?
    full specs: Engine
    Engine type Single cylinder, 2-stroke
    Displacement 293.2 cc
    Bore/Stroke 72/72 mm
    Compression ratio –
    Starter/Battery Kick- and electric starter/12V 3Ah/12V 3Ah
    Transmission 6 gears
    Fuel system Keihin PWK 36S AG
    Control Exhaust control TVC
    Lubrication Mixture oil lubrication 1:60
    Engine Oil Motorex, SAE 15W-50
    Primary ratio ’26:72
    Secondary drive ’13:40 (13:50)
    Cooling Liquid cooling
    Clutch Wet multi-disc clutch, hydraulically operated
    Engine Management System Kokusan
    Chassis
    Frame Central double-cradle-type 25CrMo4
    Subframe Aluminium
    Handlebar Neken, Aluminium Ø 28/22 mm
    Front suspension WP-USD Ø 48 mm Closed Cartridqe
    Rear suspension WP-PDS DCC shock absorber
    Suspension travel front/rear 300/335 mm
    Front/rear brakes Disc brake Ø 260 mm/Disc brake Ø 220 mm
    Front/rear rims 1.60 x 21” DID/2.15 x 18” DID
    Front/rear tires 90/90-21”; 140/80-18”
    Chain X-Ring 5/8 x 1/4″
    Silencer Aluminium
    Steering Head Angle 63.5°
    Wheel base 1,475 ± 10 mm
    Ground clearance 385 mm
    Seat height 985 mm
    Tank capacitiy approx. 11 litres
    Weight (Ready to Race) approx. 103.1 kg
    #183327
    looks about the same as the Kato….
    bar the SIX SPEED ;) :angry: :angry: :laugh:
