Husaberg reliability
Home Forums European Rides Husaberg reliability
This topic contains 1 reply, has 0 voices, and was last updated by  Damo 16 years, 4 months ago.
  • #97475
    Trent
    Reliability wise this was posted on http://www.husaberg.org by someone that hires them out.
    Here is Dustbites updated report on his bikes. He gave me permission to just copy and paste from his pm.
    Hi Dale,
    It’s our high season, that’s why I haven’t been around here.
    I quickly checked the bikes:
    oldest two bikes (Dec 2008):
    450 – 563 hr 21591 km
    570 – 505 hr 19837 km
    “newer” two 450s (March ’09):
    – 396 hr 15319 km
    – 416 hr 15930 km
    three bikes received new piston- rings and timing chain. They started consuming a lot of oil and starting became difficult.
    One bike needed a new cylinder. The old cyl. showed two light colored spots where the compression ring reaches TDC.
    at € 465,- RRP for cyl & piston you won’t hear me complaining (minus a dealer discount).
    The timing chain stretches a lot, so much that the tension rail rests on the cam-shaft gear wheel! It results in a lot of clacking noises by the hydr tensioner at low rpms.
    The good news is that the chains seems to be unbreakable. I didn’t change the gear wheels but it will be necessary next time as the Morse type chain wears out the gear wheel in a very different way as a chain with rolls.
    The 570 seems to get hotter than the 450s (well, obviously I guess). Sometimes the one-way reservoir breather-valve blocks at this bike and the pressure rises so much in the reservoir that it starts leaking at the pump flange.
    But: with one group the bike seemed to boil and loose cooling liquid. But with the next group: no problems. So it might be driver related. That’s the whole problem with fora anyway: 10.000 members and 10.000 different opinions……. And riding in my nick-of-the-woods has a different impact on a bike that elsewhere, that’s another important factor to consider.
    From a tour- business point-of-view: I don’t think there’s a better bike! Honestly, we have so little troubles with the bikes, it’s amazing.
    The shims of the exhaust hammer in, putting back a shim in the original thickness brings the gap back to specs!
    That’s very, very different from the older Husaberg models and the 2003 KTMs I owned; the intake valves were always “eaten away” by the very fine dust we have here.
    hope this kills your curiosity
    cheers,
    Adriaan
    Pretty good news for ‘bergers I’d say!
    #159581
    Damo
    Yep, I did read that. Very interesting.
    Not really that surprising however, they are THE BEST!!!!!!
