This topic contains 17 replies, has 0 voices, and was last updated by Steve 12 years, 10 months ago.
May 22, 2013 at 12:12 am #102786
to all 310 owners and people who mite know, what gearing are you using on your 310, and also what sort of fuel range are you getting with the gearing your using iv got 13 f and 48 r and struggling to get 70 km out of the tank any help would be great
May 22, 2013 at 1:00 am #242264Hi Wolfie,
My 310 had 13/50 from standard and I changed it to 13/52 trying to get a bit more punch out of the corners
I could get 90k out of it without the fuel light coming on.
What year is yours? mine was 2011 (fuel injected) and had a 8.5 litre tank, I think the earlier ones might have a 7.2 litre tank??Maybe you just ride heaps harder than me :unsure:
May 22, 2013 at 1:46 am #242265trailraider mines a 11 mod too, mate im a grand ma when it comes to riding lol slow as and upside down a fair bit too :silly: :laugh:
May 22, 2013 at 1:52 am #242266Maybe the fuel is leaking out when you have it upside down while doing a trackside inspection of the engine cases :whistle:
:laugh: :laugh:May 22, 2013 at 1:52 am #242267Actually now that u mention it I don’t get much range out of mine either :huh: mine is fuel injected, has the 8.5 tank. 2009. Wondee wjat strucky got out of it??
Going to ask stupid question now….how do you tell what gearing it runs? I usually don’t even know what gear I’m riding in most of the time ( until I start to change down and I have to just keep clicking that leaver :pinch: ).
Is it like a car and depends on what type of driving you’re doing??May 22, 2013 at 1:56 am #242268Hey OG,
Gearing is just referring to the sprockets 13/50 = 13 teeth on the front sprocket and 50 teeth on the rear sprocket.May 22, 2013 at 3:58 am #242269Yeh,I’v got 13-50 on mine to,2010 mod,stock gearing I beleve. I did a fuel run the other day,and at 80 klm’s the fuel light came on just as it started to spluter :unsure: at 82 it ran out all together and I left my fuel bottle on the bench in the shed :blush: I had to get my wife to do a rescue run.
Got the finger pointed at me ,once again :laugh:
Teza.May 22, 2013 at 7:45 am #242270you funny man trailraider :laugh: , I mite have to do what you said teza and do a fuel run till empty but ill take spare fuel unlike you :laugh: :laugh:
May 22, 2013 at 8:13 am #242271Hey Craig,,,I wouldn;t trust the reserve light at all,,on m ine I’d call it a “just ran out of fuel light”
Like yu need a light to tell yu that :laugh: :laugh:
TezaMay 22, 2013 at 9:55 am #242272Wolfie,
You could try going for a ride,hammer it or ride like you normally would for 20k or so and top it up with a measuring jug. Then work out how many k’s you travelled for the litres then work it out with your tank size.Then you’ll know the worst case and be able to estimate the range depending on the day.
May 22, 2013 at 10:01 am #242273ill try that tomorrow 2banger weve had an inch of rain today so mite be some fun :woohoo: good chance to cut the loop in around the house
May 22, 2013 at 10:40 am #242293twobanger wrote:Wolfie,
Thats exactly what I did,,figered that I would get about 100 k’s out of it,,but when it stoped there was still fuel in the tank that the pump couldn;t pick up.sounded like about a ltr when I shook it around and had a listen with the lid off.
Teza.May 22, 2013 at 10:49 am #2422741 Litre that’s a lot, might be a long shot but on my fuel pump they can become unclipped from the base and the pump pick up lifts up a touch. What this does is reduce the fuel range and leave some behind.
All that was required is a new cable tie around the pump and the body where it clips in.
May 23, 2013 at 7:35 am #242275Thi is all a bit weird to me I’ve got over a hundred ks out of mine. I have removed the backfire restrictor, fitted great exhaust one screen left in (thanks Mr Barrett!!), standard gearing and had it remapped to suit and I get what I get out of it. I am over 50 and soft as a corporate financial advisor (noooo that is not what I do!!) but i get along OK. Mine is an MY’11 … unsure … :unsure:
May 23, 2013 at 8:18 am #242276MMM! Thats interesting,,Thanks for that info guyes. I knew that I wanted to look into the maping to get more power of the bottom,maybe that has a bearing on the fuel consumption as well eh!
And I’l be having a look in the tank to,,,that could explain why it ran out of fuel just as the reserve light came on.
Cheers Teza. -
