Husky too slow
This topic contains 39 replies, has 0 voices, and was last updated by  Nick Again 17 years, 2 months ago.
Viewing 15 posts - 16 through 30 (of 40 total)
  • #115960
    chris72a wrote:
    Husky610 wrote:
    Ps Curlyman.check the footpeg mounts on your bike..sometimes they have a touch of weld or slag to upset the mating surfaces, file/grind them flat..or you could experience the snapped footpeg syndrome..snapped peg/ swollen knee and ankle..if not broken. it seems to be a bugbear of Husky TE 610’s for a few years???
    Tiny keeps breaking foot pegs, wonder if this could have anything to do with why.
    Tiny has never broken a foot peg Chris, the bolts break because of the poor design and Tiny’s, well, not Tiny!
    #116329
    curlyman wrote:
    I read in ADB blokes just changing the pipe made it run like crap…. I,m waiting for the bike shops to re-open as the dealer said he found a pipe that may be compatible…
    Ahhh…I see. It shouldn’t really be a major issue, although as I said I know of Huskies. Just when you think of every car that FI and all the aftermarket knocking about on them.
    The ECU should be adaptive, although it may alter timing to compensate for the exhaust which makes the bikes run less well. I know the Husaberg’s already have new maps programmed for various stages of aftermarket tuning :)
    As you said, best thing is to consult your dealer.
    #116330
    Nick Again
    you can throw a LEO VINCE X3 on it no propbs. i think it comes with all the Goodies for the FI. to cope with it. Apparently they get rather loud when your under it though. I still reckon you should check out the Cafehusky site though. they will answer anything, help out with any tech stuff as well. Those crazies are running them from sea level to 14,000 feet, just to see if the Injection can handle it??? I still think its nobbled somewhere? the Cats shouldnt make a diff. to it. PS> the pipe has a pair of them in it…explains why it gets soo bloody hot…So many burns Have I. :dry:
    #116592
    Two cats in the pipe :ohmy: It must be like dragging your leg across the exhaust header!
    #116614
    Nick Again
    Moto, the heat is phenomenal. I got a 3deg. burn on the right bicep, trying to hump the thing into the back of a ute. it touched me for just a frag of a sec…@#@$%^ thing !! I’m looking at tossin the heat shields and using pipe wrap. i reckon it will drop off heat and LOOK better too….maybe..:S
    #116357
    Nick Again
    I’ll bet a buck ..if he cleans thte mating surfaces ….no more probs. they have weld and uneven surfaces…hit em a file..Job done. ;)
    #116765
    That sounds like a poor design. The good thing about my Ti exhaust is that is has reduced the heat of the silencer section to a temperature that you can touch with your hand. Even after a hard ride!
    Some heat wrap may be a good idea by the sounds of it :)
    #116902
    Nick Again
    I have some serious plans for the whole system. I want to piss the ugly heat shields off and throw a barrett on the end of it. Heat wrap from the header back to the slip on. I’ve heard just puttng a barrett on it drops some serious heat. The heat shields just rattle/vibrate.I hate sounds like that coming from the bussiness area.
    #117137
    Yeah, I wouldn’t like rattly sounds either :( I’m going to heat wrap my header to just short of the muffler as the header pipe dips behind the frame. Will save melting bike pants and may even direct some of the radiant heat away from the cylinder head in the slower stuff :)
    Sounds like you have a little project on the go Husky, you should take some pics of the progress and post them up :)
    #117140
    Nick Again
    Yeah…I’ll try as i go..I have no issue with overheating to date, been in some very tight spots in very Humid heat..mates DRZ boiled, te 510 boiled..te610 Purrrrrrrrrrrrred all day..snarled a few times, bruised me a few times, but kept on purring. Strange i haven’t burnt riding pants but I sure have melted some side plates…LOL.
    #117141
    Nick Again
    MOTO, by Ti..do you mean Titanium? If yes, have you got the littler shields on the header? I hear they can get pin holes in them? Akrapovic make a nice system for these but $1800 is a touch high…Would be nice though..
    #117202
    Yeah, I meant Titanium :) The header doesn’t have any shields? It dips behind the frame above the right footpeg and shorty after connects directly to the muffler. I don’t have the full Ti system, just the muffler.
    I was going to get the Akro but it was more expensive, not in stock and didn’t offer any power gains over the (Wings) exhaust that I ended up with. The Wings gear is awesome quality and must have been one third the weight of the standard unit.
    #117203
    Jason Curley
    Thanks for all the advice…. I went riding down Grafton way last weekend and met a bloke with an 08 Husky 610… He has pissed the cats off… removed the o2 sensor and put a Barret pipe on…. he reckons it goes like shit off a shanghai, it’s not too loud and doesn’t get as hot…. sounds good to me.:)
    #117602
    The ECU should do most of the work compensating for the changes. Removing the cats will certainly get rid of alot of the heat produced.
    I’m not sure how you can remove the O2 sensor without the modifying the ECU though? It’s part of the fuel/air ratio control loop. My old Toyota Supra used to drop into a safe mode (cuts boost to turbo’s) if the O2 sesnor returned a fault signal or was removed.
    #117603
    Thank god after reading 30 odd quality posts of Moto’s :laugh: (busy today, you amaze me, you da man)I stumble across this one, its a good correct response that is informative. I would give karma Moto but its 15mins I will never get back. Oh hang it karma anyway as this one is good, well done.:lol: All pollution related senors have a performance derate feature if disconnected ( as the pollution side wont work correctly ) or the sensor fails, so people have to get it fixed :huh:
    Karma Moto
