This topic contains 53 replies, has 0 voices, and was last updated by dennis da menace 16 years, 9 months ago.
May 18, 2009 at 7:04 am #134772
Quote:Some quality 6 side sockets, and some special half size sockets, very trickTB
I think it might be a bit past that at this stage :blush:
May 18, 2009 at 7:06 am #134774Well give me a yell if you think I can help, always happy to help an Old Bull
May 18, 2009 at 7:16 am #134770Shane, there is probably 5-6 ways of attacking this problem,and many have already been suggested,I will throw my 2 bobs in, give the outside of the nut a go with some rust buster or penetrine,let it soak the longer the better,apply some Gentle heat to the cases with a hot air gun or propane torch,remember Gentle heat,next get a can of quick freeze (bunnings,auto one)spray the nut. Then use a rattle gun with a metrinch socket. That will get the bastard off;) option two,same as above but use a cold chisel, option 3 you can use a plumbers mate which is like a pipe vice grip with an extended handle.option 4 if it will fit in you could try a stud remover. Option 5 leave it alone and just turn your bike upside down and let it drain from the filler:woohoo:
option 6 wait for TB with his special tools;)
May 18, 2009 at 7:37 am #134778Shane ,
heres my 2 cents worth.
Go to Bunnings & buy the IRWEN Easy out sockets.There are worth about $50 for a set of 6. They work like a spiral so the harder you try to lossen the bolt the tighter it grips.Worked wonders.
. Good Luck.May 18, 2009 at 7:40 am #134683x 2 for tryhards method!!
May 18, 2009 at 8:01 am #134781Ha! Paydirts!
I had another look around the shed and found a 6 sided socket…but as I might have let slip, the nut was way beyond that sort of thing. I should really have looked harder in the first place before I buggered it completely.
The chisel wouldn’t work, not enough room in beside the frame rails, so I grabbed an old screwdriver (my pop just rolled in his grave!) but that wouldn’t budge it either.
So I think, in for a penny, and with a LITTLE file, make two flat sides to fit a 13 mm OE spanner. (If this doesn’t worked I’m all for emptying it by upturning the thing!)
Thank Christ that worked :woohoo:
Now, I need a new alloy sump plug. These things look like they’re spun, can anyone recommend a turner in Penrith? Luckily the filler is (or was) exactly the same dimensions!!!
May 18, 2009 at 8:29 am #134782shane-o…..i remember doin THAT on my VOR…..
i have one of these special tools, its called a shark spanner, it looks cheap but it works a treat!
(it goes the other way to undo stuff)
it fits anything from 8 to 21mm.
i inhereted it from MY pop!they still sell them at tool shops. very handy.
helped me out of my VOR predicament!!May 18, 2009 at 9:47 am #134789Ta Menace, I was thinking I needed one of those today…my old man’s got one but he’s bloody 5 hours away!
Meh, one rounded nut in 7 years isn’t so bad
May 18, 2009 at 11:40 pm #134825
AnonymousGlad you got it sorted Shane, it’s a bitch when they get rounded off.
May 19, 2009 at 7:49 am #134895Thanks for all the advice and offers of assistance.
In the end I took another route.
Time to visit some showrooms with a vernier to find a suitle replacement part!
May 19, 2009 at 9:44 am #134993get onto VORCLUB.COM
they will send you one from spaghetti land. quick smart!!
and thier sticker kits are cool. (not as cool as an OBT one though)
i reckon i got an extra grand for mine, just for the stickers, and i outlaid about AU$150….
the bloke was stoked!!
May 20, 2009 at 8:08 am #135015Ta Menace, I’l have a squiz
May 20, 2009 at 8:13 am #135276shane_vor wrote:
Quote:Ta Menace, I’l have a squizmaybe this one will help next time
May 26, 2009 at 9:17 am #135277How’s this?
$41 for a sump plug, shipped to my door direct from Italy.
$41!!!! It’s a sump plug!
Hopefully the bloke in NZ can do a better price?
I’m about to email CrossCountry Action (again, poor buggers) to see if they still have any…
Ahhh Euro bikes:unsure:
May 26, 2009 at 9:23 am #134684hey Shane,
can you take the old plug to a nut and bolt shop and get something in the same thread and length?
it’d be metric i guess. cant be that hard to get one.??? but then it might not be.
just a thought.
did i read in one of your posts that the filler is the same thread? or am i dreaming again:blush:
