important 4 klx 450r 08
Home Forums Kawasaki Bikes Kawasaki Bikes important 4 klx 450r 08
This topic contains 2 replies, has 0 voices, and was last updated by  drew 16 years, 8 months ago.
  • #96867
    aaron childs
    reading many forums whilst playing with accesories i found alot of reports regarding intake valve adjustments early.
    At 1500 i strongly reccomend you check them yourself as i trusted it to be done in the workshop service (stupid to expect detailed maintenance unless you do it yourself!)
    It apparently was checked , but later admitting that it wasn’t
    at 3200km i found my bike having trouble starting and started making enqieries
    thankfully the shop took my suggestions on hand and had a good look
    Intake was to tight and the shim needed replacing , so there was my new bike in bits because of know it all mechanics whom think they know it all (regardless what inspection scheduale states)
    IF YOU OWN A 450 TAKE NOTE AND CHECK THOSE VALVES EARLY AND FREQUENTLY AS IT IS A COMMON PROBLEM THROUGHOUT MOTO THREADS
    GOOD LUCK FELLOW QUACKA HEADS:silly: :kiss:
    #145090
    Sound advice Aarochild
    I check/adust my Kato v/v’s every 800 to 1000kms
    I have little faith in shop service schedules:(
    Murph the surf
    #145091
    do the klx suffer the same as the klr?
    i know the klr has to be checked/adjusted regularly.
    a friend has a mid 90’s klr, you know it’s time to do them when it won’t start on the kicker but will push start.
