Imported engine cases
Home Forums General Bike Talk Imported engine cases
This topic contains 8 replies, has 0 voices, and was last updated by  James Rookyard 10 years, 10 months ago.
  • #104433
    Righto, if I import a pair of XR500 cases from the U.S. to replace my damaged ones will I run into future Rego issues with the RTA in NSW? As in using the imported case with the engine number instead of the old engine number.
    #261726
    Damien Smith
    Probably be the same like when you do a engine swap on the car get it partial blueslip for ID change they check it out write down new numbers and then you lodge it with the RTA
    #261731
    Steve
    stamp your old numbers on a plate n stick em over the top.
    Ftyk en they rort us enough now being honest.
    (did I say that out aloud)
    #261727
    what model XR.
    Damey
    #261739
    It’s a 83 XR500.
    #261750
    Hiya Jimmy
    got a 83 in the shed..Promised to Boony.Best talk to him..
    Runs ok but smokey and cam chainy??
    cheers Damey
    #261728
    Richard W
    Go have a chat with your local RMS (RTA no longer) officer. they will give you the forms you need.
    #261751
    damey wrote:
    Hiya Jimmy
    cheers Damey
    If you still have it and have a price in mind let me know.
    #261732
    This is just for laughs hopefully. As the penalties for this are very heavy if one was to get caught. Rebirthing and such. Very bad. Not worth it.
