IRC VE33 Rear Tire
Home Forums Product Reviews Product Reviews IRC VE33 Rear Tire
This topic contains 63 replies, has 0 voices, and was last updated by  Anonymous 16 years, 5 months ago.
Viewing 15 posts - 16 through 30 (of 64 total)
  • #145970
    WikdBeemer wrote:
    My StoneKing is still going strong. I cant believe the small amount of wear for so much riding.
    Yeah they last forever, but wait till you put a a different tyre on and realise how much traction you have been missing out on :laugh: I used to run them they dont wear for sure, ah the search for both :P
    It’s on my list of tyres to try since it’s got such a good wrap. I’m looking to find a tyre that I like to use 9 times out of 10, a do it all tyre if you will, or one at least that does it all well.
    I’m doing the smae with the front. The Washougal and the Scorpion will be hard contender’s t beat I reckon, but this tyre could make it interesting.
    #146526
    Anyone interested in my current opinion of the IRC??
    The knobs are 6fiddy tough and are still all intact after 90km ,from what I can work out the taller side walls, although 6 ply are soft.
    Either that or I am unlucky as I put a hole in the side wall you can put your finger in,in the first 12km’s.
    I am presuming it was bad luck and other than that, it lugged up well and threw rocks at the other riders as good as any tyre I have had in the past.
    On the upside they have a rim protecting ridge on the tyre and they are easy to fit
    Although I am disappointed to have stuffed it in such a short distance,I will watch with baited breath to see if anyone else have a similar sidewall incident.
    #147766
    Dan and I talked about you tyre incident on Sunday (via Blue tooth) while riding some really nasty sharp flint style rock and thought it would have been a one off
    Years ago I put a stick through the side wall of a $240 desert tyre as used by 80% of the safari field, the shop couldn’t believe it, it happens as you said its 6 ply and its no taller in the wall profile then a Pirelli Scorpion or a ED78 Bridgestone. Even bad luck can happen to you, maybe a garlic necklace next time :P (private joke)
    Paul Boland
    Guys,
    I’ve had my eye on a particular tyre of late, but not so sure if it will fit on the DRZ.
    Informed opinions appreciated.
    #147768
    Paul
    It might be a bit wide for the tight single track TW.
    Good to see she bottles her f^rts and pipes it into the engine, enviro friendly that eh!
    #147774
    I pulled the tube out of the tyre this arvo and it was in fact a 19″ big wheel 85 tube that saved the day for me yesterday.
    I gave the irc the once over and here are the pics.
    With no tube.
    Here it is with a new ultra heavy tube in.
    What are your thoughts?? Should I replace a 90km old tyre?
    #147821
    good to see you were able to complete the ride Mick;)
    With the Tyre I would still be using it,maybe put a Vulcanizing patch on the inside and a dab of black silastic on the outside, shouldnt give you any problems
    + 1 for putting a patch on the inside.
    should live out it’s live until bald.
    #147830
    Yeah I suggested it on the phone today as well, needs something, but if he has it back together he wont do anything about it :laugh: and it looks back together
    Yeah you are probably right……..:laugh:
    Might put a dob of silastic in the hole.
    #147833
    i got a gash like that in the side of my back pirreli scorpion mick but it stayed pumped up :P
    #147836
    Mine probably would have stayed up if I had a heavy duty tube in. But I didn’t and paid the price.
    #147847
    just keep using the tyre she will be right reckon that can happen to any brand tyre mick seen a metzler with a gash the other day to
    #142642
    For the time it takes I would whip the tyre off and patch from inside, even with heavy duty tubes it could become a tube pinching machine and nothing worse than mutiple punctures to ruin your day!!:dry:
