It’s Done
Home Forums General Bike Talk It’s Done
This topic contains 49 replies, has 0 voices, and was last updated by  Anonymous 16 years, 3 months ago.
Viewing 15 posts - 31 through 45 (of 50 total)
  • #156643
    Good stuff Moto, into the brethren you come, the smell of castor oil in your nostrils, and premix in yer blood.
    Eric Gorr shall be your new diety, and the bible shall “tuning two strokes for fun and power”
    and nevermore shall you be required to change a shim or grind a valve.
    #156645
    Daniel Baker
    the maintenance wasnt an issue for moto anyway… he never did any
    #156456
    LC4skin wrote:
    Moto burns the fridge when he gets sick of mixing vodka and coke
    and has sucked his goon bag dry :laugh: :laugh: :laugh:
    #156646
    I’ve never changed a shim or ground a valve in my life :laugh:
    My 450 has been a great bike, the 300 has a lot to live upto.
    #156434
    Nathan
    Will the 300 be the bike to keep a smile on my dial
    I went from 08 450 to 09 300 bloody better believe it will. Will take 4 or 5 rides though
    Will the torque be sufficient to keep me happy coming from the 4 banger?
    theres plenty of torque.you will just have to rev it a bit more till you get used to ridin it at first and figuring out how the torque works on a 300 then no problems
    Will my steering damper swap straight over?
    yes
    Will I get someone else to swap my PivotPegz over?
    no
    Will my 777 race number make me go fully sik factory fast?
    of course it will
    Will I get used to the lack of engine braking?
    after you hit a couple of trees an overun corners on your first 2 to 4 rides then sure you will. then you will hate engine braking and enjoy using brakes and sliding in effectively
    Will I get so annoyed with mixing oil that I burn the bike, claim on insurance and go buy a Berg?
    its not that hard write out a table on oil mixtures. get a measuring cup/device and mix. easy.
    All very valid questions…..soon to be answered
    i went through the gammitt of emotions (thats alot) as you did. the main point i will make is this. the 300 for me is a better bike. lighter for me, faster through tight stuff, makes you a better rider. every time i look at it it gives me a stiffy. the 450 didnt do this. When i have a stiffy i feel good.
    i hope this helps.
    cheers
    TF2
    #156423
    Liam
    Mixing oil at 40:1 I in my mathematical wisdom devised that 0.25 or 0.025 x no of litres gets how much you add.
    Tolerances are like chipper stuff so don’t stress to much.
    #156636
    Liam
    Ollie wrote:
    yeah,nice going moto B)
    Four Strokes – 1 power stroke – 3 wear strokes :laugh:
    Not to mention all the wasted material on top of the stroking action.
    Be a good half dozen 2 stroke pistons wasted in every 4 stroke head region.
    #156904
    It runs at 60:1 which is 16.66666666666666666667 ml’s per litre ;) Like someone else mentioned I’ll do a little chart. It doesn’t detract from the fact that I have to have a little chart and piss about with it in the first place though!
    Nice responses tf2, good to see you made the switch and are loving it. I think I’ll be right, just playing devils advocate :dry:
    #156970
    And that will be so easy to work out when you stop at a servo to top up and add 7.6 litres
    Easy eh :laugh:
    Exactly!
    I’ll have the measurements written down and will know close enough after the first few rides :)
    #156972
    It might vary between 30:1 and 90:1 though :laugh:
    #156973
    Paul
    Is it true that some Euro 2Ts can run with 100:1 fuel mix?
    #156974
    I don’t know but it’s bloody crazy if they can!
    #156975
    They can, yes.
    but it may not be for very long :silly: :dry:
    i’m unsure too.
    but a guy testing for Penrite oils when they were developing their 2T oils, tested bikes at 100:1 to see how long it would take for them to detonate :ohmy:
    #156435
    Trent
    All very valid questions…..soon to be answered :dry:
    Well it seems that we have the answer to this question. I was confused as to why Moto raced under an assumed name but it became apparent through the clip as I’m sure you’ll see.
    [video]http://www.youtube.com/watch?v=SbHIxXiFAyA[/video]
    Keep your head down Moto, there’s only one way to head from here… actually given your apparent navigational ability there’s probably several ways you might head but I’m sure you’ll get there mate ;)
