JB Weld
Home Forums General Bike Talk JB Weld
This topic contains 4 replies, has 0 voices, and was last updated by  Bill 16 years, 6 months ago.
  • #97135
    Trent
    Hey guys is this the best stuff for your spares pack? I figured the kwik stuff would be better since you don’t want to be standing around on the side of a trail for a long time. Only issue I see is that it isn’t as heat resistant so if anyone has used it or knows not to use it could you chime in.
    Also is there a convenient place to grab it that’s cheaper than $20?
    Cheers.
    #151850
    Don’t have any experience with it but I have seen it in a fair few bumbags, so must be O.K. (for an emergency fix that is)
    They are all more or less the same AB, I haven’t used this one but it seems ok and $20 seems more then fair
    Here is some info I found and the product of theirs I would carry, I carry one very similar
    Description:
    J-B Stik Weld is a hand kneadable, steel-reinforced epoxy putty adhesive/sealant that will plug holes and make permanent repairs on wet and dry surfaces. It will even cure completely submerged in water or GASOLINE! Simply knead thoroughly, with your fingers, a portion necessary for the repair and apply. J-B Stik will fully cure 20-30 minutes; and can be drilled, sanded, filed, tapped, machined, and painted. J-B Stik requires no tools or “prep time”, and makes no mess.
    How does it work?
    Hope all that helps
    Trent
    Hmmm $12 from the UK and risk customs seizing it or $28 locally…..
    #151896
    Bill
    I just ordered 3 off packs from GB – total cost of $27.00au delivered.
    http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=150370607158&ssPageName=STRK:MEWNX:IT
