Jeffro’s XTZ660 Tenere Engine Rebuild
Home Forums Yamaha Bikes Yamaha Bikes Jeffro’s XTZ660 Tenere Engine Rebuild
This topic contains 36 replies, has 0 voices, and was last updated by  Jeffrey Smith 13 years, 8 months ago.
Viewing 7 posts - 31 through 37 (of 37 total)
  • #226688
    Hey Jeffro,
    Great stuff there mate!! :woohoo: Well done. The other breather that you have circled is just for the diaphram to move up and down. on the original carby it went up under the tank to atmosphere. Nothing to worry about mate well done.
    Lefty
    Hopefully it is a little better on fuel than the old carby, let me know how you get on with it.
    Left B)
    #226698
    Thanks Lefty, going out tomorrow for a run and see how it goes.
    #226702
    Mick Pilgrim
    Jeffro,
    hope the carby works OK
    The DR650’s have a small filter attached to a short length hose to the diaphragm breather to help keep a bit of dust out. It sits under the seat at the back of the tank.
    Might be worth doing
    Mickp
    #226709
    Thankd Mick but that is the carby I took out, the one I put in doesn’t have the breather.
    Rode about 200km today in all sorts of terrain, form 110km/h highway to rutted muddy trails and she ran perfectly. The only complaint really is that the throttle action is quite stiff.
    #226736
    Jeffo if I remember correctly your throttle grip rubs on the end of the bar at the bar end. Just check it out and make sure it is ok. Or the other carbie may have a stronger return spring. Glad to hear that she ran well mate. Was it better on fuel?
    Lefty
    #226822
    When I picked the bike up from Lefty I rode it home getting fuel at Colo on the way. I did 222km before refueling it and it took 12.5 litres which works out at 5.63l per 100km.
    After I put the other carby on I rode it o friday and did 235km on a variety of roads and trails, I refueled it today and it took 11.4 litres wich wokrs out at 4.85l/100km.
    Although it’s not a perfect test as I didn’t ride the same roads and trails as last time and I also varied the throttle a lot more last time running it in on the open sections, that should give me around 350km per tank.
    #223217
    Sounds like a win win to me so far mate ;)
    Get the big girl out for our ride in Sept , that`d be a good test B)
