Joining Links
Home Forums Tech Help Tech Help Joining Links
This topic contains 44 replies, has 0 voices, and was last updated by  Dean 16 years, 6 months ago.
Viewing 15 posts - 16 through 30 (of 45 total)
  • #136680
    I have one of those chain breakers from Balards. I tried using it to press the side plate on but when I push on 1 pin it doesnt close up on the other one enough to get the clip on, and when I tried it in between the pins it bent the plate before closing it enough to get the clip on.
    I just ordered the joining tool (after reading your post) so hopefully I will have better luck.
    Thanks all for the tips.
    #136759
    KTC chain tool. THe DUCKS GUTS of chain breakers, this is what I have and it will set you back about $AU450.00.
    Here it is in action.
    #136762
    shane
    If you’re talking about making a press-type setup to squash the plates on before fitting the clip Ollie, put me down for one as well. It’s been so long since I did one:blush: I think I use vice grips and held my tongue this way.
    #136754
    I’ll purchase one Ollie if you can make them ;)
    Me too for 1 if you make them Ollie:)
    #136801
    Trent
    I had a fairly interesting experience putting my new chain on when I learnt how to fiddle with the buggers a bit. Just make sure that the bushing is sitting nice and evenly spaced before you put the joining link on or it’ll be very hard if at all possible to get the clip on and it’ll jam the o ring and reduce freedom of movement.
    I use vice grips and a tent peg placed between the bushings to make sure I squeeze the backing plate past them.
    Chain breakers are definitely a great advantage. [img size=820]http://www.obtrailriders.com/media/kunena/attachments/legacy/images/Chain_parts.JPG[/img]
    #136806
    Glenn
    Ollie,
    I will purchase one also if you decide to go ahead and make them.
    Also, sorry to here about your finger troubles!!!!!!
    Glenn
    #136811
    blue450 wrote:
    Ollie,
    Glenn
    Untill you meet Ollie you will not know the depth of his finger problems!!!LOL
    How many fingers have you got Ollie??
    #136814
    blue450 wrote:
    Ollie,
    Glenn
    5 and 3 x 1/2 :laugh:
    /good onya Boofhead:laugh:
    #136823
    Bill
    Ollie wrote:
    blue450 wrote:
    Ollie,
    Glenn
    Fark i thought 9 2/3 was bad
    #136830
    KTM Bull wrote:
    Ollie wrote:
    blue450 wrote:
    Ollie,
    Glenn
    not counting thumbs tho bull:)
    #136832
    Ok as promised I have just finished making a dozen “O” ring chain press. I made them from 6mm heat treated steel so they should be strong as. I used them as a training aid for my boys at work to get them familiar with some of the machinery (mill and vertical drill press) and Hand tools (taps and die) and a bit of an insight into basic metalurgy. Those that have indicated that they want one are first on the list, so probably means there is about 7 remaining. These are all individually hand made and will be a must have in your toolbox. If you want one they are $20 each plus postage if recquired ($6 postpac satchel anywhere in aussie) I will be able to deliver to Louee
    sorry no pics yet but I did a trial run and it worked pretty good B) sorry if I have forgotten anyone :dry:
    People who have indicated they want one are
    Moto
    Ktm rat
    wickedbeemer
    Shanevor
    blue 450
    white rocket
    xytransit
    ECKS
    Thirsty
    B)
    hay Ollie can i get one of you at Louee may use it there and give it a test run don t no if my chain and sprockets will make it through the 3 days
    #136681
    XY-boat anchor, too Please :laugh:
    could you please PM me your details so i can D/T funds ;)
    once pay goes in :blush:
    Thanks Ollie B)
    #152709
    rocket and Drew you are on the list B)
    Same here, I’d like one. Let me know the details and I’ll deposit the $$ then let you know where to post it. :)
