KASUYAHO’s XR650R
Home Forums Your Garage KASUYAHO’s XR650R
This topic contains 37 replies, has 0 voices, and was last updated by  Glenn Batho 15 years, 2 months ago.
Viewing 8 posts - 31 through 38 (of 38 total)
  • #192432
    Nice photos :) Why were the valve and springs replaced? Who did the head work I only ask cause it looks so familiar
    Glenn Batho
    TB,
    The valves were replaced as they were worn out,
    like pizza cutters :)
    When we measured the stock springs they did not have alot of open pressure.
    So we replaced them too.
    The intake work was done by a mate who runs a Top Fuel Bike at the drags.
    Allan Herriman…..Al is one of these guys when everyone at 18yrs was out on the piss,
    Al was in his shed playing with engines, porting the mower head etc :)
    It is hard to find guys who specialize in bike cylinder heads.
    #165119
    Brad Raffin
    you might want to replace the metal material in the air box with a fine stainless steel mess which will allow it to breath but also keep the mess out of the airbox. you might also want to use maxima air filter oil.
    #192525
    Glenn Batho
    HRC give a size for the side cover cutout, so no doubt they played with sizes to get whaat they thought was the right size.
    Xr’s only sell a kit for the side cover that will go over the top of the holes i made in mine.
    This kit does come with alloy plates and finer mesh.
    As you have said a finer mesh is the go, i believe so too.
    I use Motul filter oil, petrolium based oils are better than the no toil type filter oil,
    What is the advantage of Maxima air filter oil ?
    #192431
    kasuyaho wrote:
    Cylinder head work [img]http://www.obtrailriders.com/media/kunena/attachments/legacy/images/P10003411.JPG[/img]
    thats rough mate check out powerflow heads web site looks like it was done with a rotary file :unsure:
    #193261
    Glenn Batho
    It looks rough from the discoloring.
    What he did was make alloy wedges that are bolted into the floor of the intake,
    then it was covered with resin first then Manely resin which is fuel resistant.
    In drag applications they just fill the intake with resin,
    but with the heat cycle of our bikes, heating and cooling the resin would fall out.
    Also if the port is too smooth this will reduce flow due to fiction on the walls of the port,
    so good head porters will leave the port wall finish rough to produce eddies.
    What he has done is reduced the port volume, this is what this head needed to make more torque,
    by reducing the port volume / smaller port, it increased the flow of the head.
    The trick what he has done here is by reducing the port runner size it makes the bowl area
    under the valve larger in volume by comparison.
    This might sound nothing really that big, but what it does it this.
    It increases air speed in the port and,
    When the intake valve closes the air does not stop moving,
    it keeps moving towards the valve and with a larger bowl area the pressure is inceased in this area.
    Drag race guys have been doing this since the 70’s when in some classes they were not allowed to increase the valve size
    as the size of the valve was a restriction.
    With this head the valve size is not a restriction.
    With the pressure increase in the bowl area of the port, and the air speed higher,
    when the valve opens again….being a higher pressure in the bowl area the air will move quicker into the combustion chamber,
    plus the air speed in the port is higher than it was at stock so there is an advantage there too.
    Being fuel atomization is better, which helps to create a better burn in the combustion chamber
    which creates more power.
    There are alot of head porters out there that just make the port larger,
    flow the head and give the head back to the customer with big flow numbers.
    They put it on there engine and it makes power up top but in the lower rpm range it is sluggish
    and not very responsive.
    Due to low air speeds in the port.
    With this head by putting on a smaller carby or installing larger valves
    it will compound the problem with lower air speeds again.
    Myself i never realized all this until i went and worked a little for this guy
    in the US, Dave is retired now but in his day was one of the best 10 guys in head development
    and engine building in the world.
    How good was he,
    well he had a 292ci small block chev, with steel heads, 2 valve, roller cam,
    single 4 barrel carby, cast intake manifold and it made just over 600hp.
    That is a touch over 2hp per cubic inch.
    Our 650R makes 1.2hp per ci, the latest WR type so called high tech engine makes 1.8hp per ci.
    there 4 valves engines, dave was a 2 valve engine.
    And dave made that power 40 years ago :)
    Dave’s car back then. oh and he did do bike engines too, Harley’s for Probike. 47627_1466924634639_1279231998_1067751_5356802_n.jpg
    #165069
    Brad Raffin
    For all of the testing that has been done especially in the desert Maxima FFT is the only filter oil that will keep the dust out. 7 Years and more than 30,000 kms at finke on two xr650’s and every honda out there runs the oil. It is the stickiest around.
    #165070
    Glenn Batho
    Thanks Brad i will keep a look out for it next time i go to get filter oil.
